AUDIOPHONICS 5 Pin DIN to Stereo RCA Cable with Ground Wire OFC Copper Gold Plated 1.5m
This cable assembled in France by Audiophonics integrates on the one hand a 5 pin DIN connector and others by two RCA connectors. A special cable that will allow you to connect some devices requiring this type of cable, but also some vintage devices.
Reference : 13084
39,90 €tax incl.
33,25 € tax excl.
Audiophonics
5 pins DIN to Stereo RCA with ground wire for Gold plated OFC Copper 1.5m
Audiophonics MA5 8088 Câble DIN 5 Broches vers RCA Stéréo avec Fil de Masse pour Bang & Olufsen Cuivre OFC Plaqué Or 1.5m
The complete cable consists of a cable Sommercable Onyx 2025MKII 24AWG shield with OFC copper conductors, DIN connector 5 pin Rean NYS322G with gold plated contacts and finally two RCA connectors Hicon CM06-RED / CM06-NTL Also Gold Plated. This design provides the cable with very good signal conductivity and durability.
Audiophonics MA5 8088 Câble DIN RCA Fil de masse
Ground wire version
In this version, the cable also incorporates a ground wire with copper conductor and gold-plated fork connector. This cable is therefore ideal associated with a vinyl turntable, in order to reduce the earth loop as much as possible and reduce parasitic currents. The cable wire used is the model Elecaudio FC105T, OFC Copper with 0.5mm² section; and FEP insulating sheath.
Wiring diagram
audiophonics-ma5-8088-din-rca-inpage12.j
Cable type5 pins DIN to stereo RCA with ground wire
Connectors1x male 5 pins DIN
2x male RCA (white/red)
1x spade connector for ground wire
Length1.5m
Sommercable Onyx 2025 MKII Cable
Section24 AWG (0.205mm²)
ConductorsOFC copper
Internal conductors2 x 1 x 0.25mm²
Sheath material / external diameterPVC / 3.8 x 8.5mm
Copper strands per core32 x 0.10mm
Conductor insulationPE
ShieldingBraided copper
Optical overlay90%
Operating temperature-25°C - +70°C
REAN NYS322G Connector
Connector typeMale 5 pins DIN
Contacts platingGold
HousingNickel
ColorSilver
Hicon CM06-RED / CM06-NTL Connectors
Connectors typeRCA
ColorSilver
Ground wire
Cable modelElecaudio FC105T
MaterialOFC Copper
InsulationFEP
Conductor section0.5mm²
Cable design45 brins de 0.12mm
External cable diameter1.5mm
Connector typeGold plated spade
Length (m)1.5
ShieldingYes
ConnectorRCA
ConnectorDIN
This cable assembled in France by Audiophonics integrates on the one hand a 5 pin DIN connector and others by two RCA connectors. A special cable...
