ATAUDIO RIBBON Flat Speaker Cable Silver Plated OCC Copper 2x1.5mm²
This ATAudio Ribbon flat cable sold by the meter is ideal for connecting speakers to a HiFi system, its format allowing it to be easily concealed. It also benefits from a very good manufacturing quality, its 14 conductors being made of high purity silver plated OCC copper for a maximum conductivity. Each conductor is isolated from the others by a FEP sleeve, effectively limiting interference.
4.8 / 5
Reference : 16852
9,90 €tax incl.
8,25 € tax excl.
Shipping date: 22-04-2025.
Câble vendu au mètre
ATAudio Ribbon
ATAudio Ribbon câble haut-parleur plat cuivre OCC plaqué argent 2x2.75mm²
Product typeSpeaker cable
ConductorsSilver plated OCC copper
Diameter / conductorØ0.5mm
Number of conductors2*7
InsulationFEP
Diameter / wireØ1.5mm
Section / pole1.25mm²
Total Width27.85mm
ColorSilver
QuantitySold by the meter
Diameter (mm)N/A
Number of conductors14
Insulation materialFEP
ShieldingNo
Section (mm²)1.5
Ground / ShieldingNo
5 reviews
Remarquable
Ecoute très linéaire et détaillée mais avec une légère perte de dynamique. Peut être est ce du Dia total. Il a suffit d'ajouter un fil plein de 0,8 mm2 de CU/PTFE et la dynamique était de nouveau là dans rien retirer aux qualités du câble. Très satisfait, surtout compte tenu du prix. Service Audiophinics au top comme toujours.
This review has been posted for ATAUDIO RIBBON Flat Speaker Cable Silver Plated OCC Copper 2x1.5mm²
Cables
I'm really impressed with the price to performance ratio of this cable. If you are looking for open and airy sounding cable with really good bass definition this is the must try cable.
Taken by surprise
Got 6m pair to run under a newly laid wooden floor away from system into an adjacent room as a trial run. Was using 2M pair of Nordost Red Dawn (R. D.) into B&W 805s in old setup. A 6M pair of R.D. would have been €€€€. The bass response is so much better & wider soundstage from this ATAUDIO ribbon cable. Thicker conductors compared to R. D maybe help? Treble is very similar to R. D also. Using a Copeland CTA405 so the cables are a fraction of the total setup but really really surprised at detail level. Another 20-30 hrs of burn and these could be recommendable to my hifi buddies. Starting to wonder if spending €€€€ on cables is snake oil. Fast delivery to Ireland and we'll packaged. Will purchase again from audiophonics
WOW !!! Best cables I had so far. Terminated with M AUDIO BS-210G Banana Plugs they are by me very good solution for Hypex Ncore amp and my System Audio speakers. Simply awesome.
Unbelieveble what you get for few euros.
A true bargain
A remarkable speaker cable for the money. Exeded my expectations. It does have the sonic signature of the materials and the geometry used. It is fast, very clean and detailed, with exelent micro and macro dynamics, deep controled bass, lush midrange and very extended and clean highs. Beware though. It's not for the novice DIYer. It will demand serius skill and precision tools to terminate it correctly.
This ATAudio Ribbon flat cable sold by the meter is ideal for connecting speakers to a HiFi system, its format allowing it to be easily concealed....
