MOGAMI 3103 Speaker Cable OFC Copper 2x4.mm² Ø12mm
Mogami 3103 is a high quality speaker cable designed to allow your audio devices and speakers to reach their full potential. Each conductor, with a cross-section of 4mm² (12AWG), is made from OFC Mogami Neglex Copper in a configuration designed to provide transparency and sound precision.
4.9 / 5
Reference : 5239
12,50 €tax incl.
10,42 € tax excl.
Shipping date: 15-04-2025.
Câble au mètre
Mogami 3103
OFC Copper Speaker Cable 2x4.mm² Ø12mm
Mogami W3103 Câble HP Cuivre OFC 2x4mm² Ø12mm
Mogami 3103 is a high quality speaker cable designed to allow your audio devices and speakers to reach their full potential. Each conductor, with a cross-section of 4mm² (12AWG), is made from OFC Mogami Neglex Copper in a configuration designed to provide transparency and sound precision. The cable can be used both at home and for professional purposes.
Product typeSpeaker cable
Conductors number2
Conductors materialOFC Copper
Conductors section4mm² (12AWG)
Conductors insulation diameterØ4.5mm
Insulation materialPVC
External diameterØ12mm
External sheath materialFlexible PVC
Weight / 100m20kg
DC resistance0.005Ω/m
Inductance @ 20°C 1kHz0.6µH/m
Capacitance @ 20°C100Hz : 106pF/m
1kHz : 93pF/m
10kHz : 83pF/m
50kHz : 76pF/m
100kHz : 74pF/m
Max. voltage500V DC (15s)
Working temperature min / max-20°C / +70°C
QuantityCable sold per meter
Diameter (mm)12.0
Length (m)Sold by length
Number of conductors2
ShieldingNo
Section (mm²)4.00
Ground / ShieldingNo
91 reviews
Happy with the result. Need another 3m piece
This review has been posted for MOGAMI 3103 Speaker Cable OFC Copper 2x4.mm² Ø12mm
très bon cable
Suite à un changement de placement des HP, les distances ampli-enceintes se ont largement raccourcies et donc j'avais besoin d'un nouveau cable HP. Suggéré par M. Aubert (Audiophonics) ce cable convient très bien à mes enceintes à 3000€. Qualité irréprochable, rendu sonore equilibré dans tout le spectre. Je suis très content de cet achat avec un pris assez modique.
Good value cable
after I changed the location of my hifi system, I needed a long speaker cable and I wanted to try Mogami.. considering that I use over 100 times more expensive silver cables from renowned manufacturers, I did not expect any spectacle in the sound. Mogami turned out to be a great cable for the value and I am pleasantly surprised by the sound quality.. after all we are talking about a wire that costs 11€/m..
j'ai du mal à comprendre
Bonjour à tous.
J'ai testé ce câble sur mon installation, Naim supernait3, JMR cantaile jubilé, Atoll MS120.
J'avoue avoir du mal à comprendre les nombreux avis positifs sur ce câble. Il est terne, très mou dans le grave et peu définit dans le médium aigu. Les voix deviennent tristes et les timbre voilés dans un flou à la David Hamilton.
J'imagine que sur beaucoup d'installations, il corrige un coté agressif de l'aigu, Pour moi, le but d'un câble est de transmettre, pas de corriger. Démonté au bout de 50 heures d'écoute.
par contre 5 étoiles pour le service Audiophonics, il est rapide, définit, bref, tout l'opposé de ce câble.
Pierre
MOGAMI w31003 4mm2
Avec le bon conseil de Mr David Auber , j'ai commandé ce câble pour faire jouer mes Focal Aria K2 liées à un Yamaha RN 2000 A (2X9 mètres) . Pas du tout déçu du résultat tout est là et dans tous les registres. Pour moi, c'est un bon mariage, je ne vois pas ce qu'un autre câble plus onéreux pourrait m'apporter de plus !
Merci Audiophonics.
Mogami 3103 is a high quality speaker cable designed to allow your audio devices and speakers to reach their full potential. Each conductor, with a...
