NEOTECH NEMOS-3080 Speaker Cable UP-OCC Copper 2.1mm² Ø12.5mm
The NEMOS series from the manufacturer Neotech is the culmination of long research in the field of audio cables. The Neotech NEMOS 3080 loudspeaker cable combining PTFE insulation and OCC pure copper conductors with a rectangular section has a special architecture allowing a strong reduction in the effect of inductance and capacitance.
4.9 / 5
Reference : 11410
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 10-04-2025.
NEOTEC NEMOS-3080
Speakers cable copper UP-OCC 2.1mm² Ø12.5mm
NEOTECH NEMOS-3080 Câble Haut-Parleur Cuivre UP-OCC 2.1mm² Ø12.5mm
OCC copper
Neotech is considered a leader in the production of cables using UP-OCC copper developed by Professor Ohno of the Chiba Institute of Technology in Japan. UP-OCC is 99.99998% pure.
UP-OCC is considered the "ultimate" conductor used today. It is a particular constant temperature copper extrusion process leading to a "mono-crystaline" copper structure. It makes the signal passes without breakage and impurity with better resistance to corrosion over time. This cable will keep its natural properties thanks to its PTFE insulation and its OCC copper.
The result is surprising, combining listening qualities that are often contradictory, such as a seat in the bass and a readable, natural sound stage with High Definition in the midrange without auditory fatigue.
Cable structure OCC NEOTECH NEMOS-3080
Structure comparaison of copper OFC et OCC
Technical caracteristics
SpEcifications
Product typeCâble de haut- parleur (2 conducteurs)
ConductorCuivre UP-OCC
Insulation3 layers: PTFE and Polyethylene in second layer, PVC outer sheath
Total section2.1mm² / 14AWG
Thickness / conductor0.63mm
Width / conductor2.4mm
Diameter (mm)
  • 12.5
Length (m)
  • Sold by length
Number of conductors
  • 8
Insulation material
  • PTFE
Shielding
  • No
Section (mm²)
  • 2.00
Conductors material (Cable)
  • Copper
Conductors Plating (Cable)
  • None
Ground / Shielding
  • No
13 reviews
Excellent RQP pour un OCC enceintes
J'ai fait monter ce câble avec fiches bananes Viablue T6S, résultat, belle scène sonore, douce et détaillée avec une neutralité respectée, le prix est ultra compétitif. Pas noté que une c'était en dessous d'un Tellurium Ultra Black beaucoup plus cher, je voulais être en full Neotech sur mon installation, disposant d'interconnexions OCC argent de la marque.
This review has been posted for NEOTECH NEMOS-3080 Speaker Cable UP-OCC Copper 2.1mm² Ø12.5mm
Clean and defined cable
After months of listening i can say that this cable fulfilled my expectations.Character of this cable is neutral but not analytical and cold,it's flowed and polite on high frequency range.Only when the recording is bad will it be felt, but never so much that it will bother you.Give it a good source and amplifier and it will show its quality in a positive way and put a smile on your face.Greetings from Croatia with one satisfied customer who enjoys every musical moment with this cable.
And i must Thank you Audiophonics for offering another excellent product for us music lovers at an affordable price.
Musicalité. Equilibre detaillé
Monté avec cosse cuivre occ et fixé au trou des borniers. Simple et trés efficasse. Prendre son temps pour enlever la gaine et pas oublier la gaine fine transparente sur le fil. Quatre fils plat total 2mm2. Les enfilé apres traitement au desoxi gold et sertir a la pince. Attention pas de blindage. Evité de passer ses câbles pres de source electrique. Les iem sais pas bon vous pouvez si probleme acheter ici ine gaine cu etamé. Tres efficasse qui n influe pas les perf. Recommander
High quality sound
Excellent cable for current demanding speakers and matching powerful amplifier Effortless delery in the hole frequency area that my speakers can deliver Relaxed, full of details and never getting harsh in treble even at high listening levels Super satisfying
Excellent Cable for reasonable price
Sound is excellent, very broad and deep soundstage.
Clear without irritating highs. Bass is also ver accurate.
To remove the insulation is very diificult and time consuming, also the termination with connectors is not that easy.
Still the sound quality was worth all the hassle.
The NEMOS series from the manufacturer Neotech is the culmination of long research in the field of audio cables. The  Neotech NEMOS 3080...
