UP-OCC Copper Speaker Cable 9AWG Ø23mm
The Neotech NES-3002 joins the brand's wide range of high-end loudspeaker cables. Its unique design allows it to participate in a precise and rich sound reproduction over the entire bandwidth, notably thanks to a perfect insulation and conductors promoting an excellent conductivity.
The cable has two conductors, each consisting of 19 independently insulated single crystal UP-OCC copper wires with a combined cross-section of 6.63mm² (9AWG) and a diameter of Ø2.9mm. Each conductor is insulated by a Polypropylene sheath and then by a PVC sheath. Both conductors are then surrounded by a filling composed of Polypropylene and non-woven textile. This is followed by two PVC sheaths. Finally, the cable is covered with a stretchable braided nylon sheath.
The conductors are made of monocrystalline UP-OCC Copper, specially developed by Professor Ohno. This ensures an extremely high purity of 99.99998%. It thus offers maximum signal conductivity for high-precision sound reproduction.
Product type | Speaker cable |
Number of conductors | 2 (19 single-crystalline UP-OCC copper strands insulated per conductor) |
Conductors material | UP-OCC Copper |
Conductors material | Ø2.9mm |
Total section | 9AWG (6.63mm²) |
External diameter | Ø23mm |
Internal sheath | PVC |
Conductors insulation | Polypropylene (PP) |
Filling | Polypropylene Non woven fabrics |
External sleeve | Braided Nylon |
Quantity | Sold by the meter |
Diameter (mm) |
Length (m) |
Insulation material |
Shielding |
Section (mm²) |
Conductors material (Cable) |
Conductors Plating (Cable) |
Ground / Shielding |
