OYAIDE ACROSS 3000 Speaker Cable 102SSC Copper 2x 2.8mm² Ø9.2mm
The Oyaide Across 3000 cable is now available by the meter. Take the opportunity to enhance your custom audio installations with these high quality speaker cables.
4.8 / 5
Reference : 12621
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 22-04-2025.
acheter cable across 3000 au metre à la coupe
High quality speaker cable sold by the meter
Across 3000 cable speaker cable by Oyaide
The cross-insulation structure uses a layer of air as a shock absorber. This not only minimizes electrostatic stresses and preserves the definition of high frequencies, but also limits mechanical stresses. It is therefore a robust cable that can adapt to the specific geometry of your installations.
Across 3000, a durable cable for a sound of great neutrality
Structure of across 3000 cable
The strands are formed using natural diamond combs. This feature allows to produce smooth-surfaced strands and to maximize the conductor density while avoiding structural inaccuracies. The conductor structure is formed by a twisting process involving three different strand diameters. This results in a high density twisted structure ideal for all installations requiring a clean and precise signal.
A design oriented on the purity of the signal
Speficitiy of 102SSC conductor
The 102SSC precision conductor has been specially developed to deliver incredible sound quality. Its construction uses exclusively virgin copper. The manufacturer prohibits even the use of recycled copper to guarantee a driver of exceptional purity.
Caracteristics :
  • Structure : CIS (Cross Isolation Stabilizer)
  • Conductor : 102SSC (Super Smooth Copper)
  • Internal Cruciform Insulation :  Polyolefine
  • External Insulation : Polyéthylene
  • Halogen-free audio sheath
  • Conductor Resistance : 0.63 Ω / 100 m (temperature 20°C)
  • Permittivity : 34 pF/m (1kHz)
  • Total width of 18.4mm / Thickness of 9.2mm
  • Conductor cross-section : 2.8mm² (12.5AWG)
  • Sold by the meter
Diameter (mm)9.2
Length (m)Sold by length
Number of conductors2
Insulation materialPE
ShieldingNo
Section (mm²)2.8
Ground / ShieldingNo
6 reviews
Super
This review has been posted for OYAIDE ACROSS 3000 Speaker Cable 102SSC Copper 2x 2.8mm² Ø9.2mm
Câble haut niveau
Je reviens sur mon avis précédent
Câble utilisé en tant que câble pour le grave sur des enceintes FH
Laisse tout passer avec un grave et un bas medium bien maîtrisé
Du Oyaide !
En rodage
Câble monté sur le hp du grave
Besoin de rodage mais prometteur
Exceptionnel
Câble d'un équilibre et d'une transparence exceptionnelle , petit « inconvénient » sur mon système il a mis en évidence de façon criarde un point faible qui était le câble de modulation dac-ampli que j'ai du changer pour un modèle mieux équilibré , depuis c'est que du bonheur. Branché pour ma part câble nu , sans fourche ni banane...
 (3)
cable Oyaide
Livraison 5/5
Produit conforme à la description.
Cable un peu "rigide" donc selon votre installation privilégier : Connecteurs HP Fourches ou
à serrage coaxial (ex : ATOHM WT-LMB Fiche Banane).
ECOUTE : Après un petit temps de rodage (~ 48hrs) ce cable délivre toutes les informations émises par la source.
Ecoute "tridimensionnelle", droite, sans complaisance et de qualité.
Ayant dénudé mon ancien cable KIMBER KABLE 8VS, pour ma part celui-ci est plus aisé à dénuder.
The Oyaide Across 3000 cable is now available by the meter. Take the opportunity to enhance your custom audio installations with these high quality...
