OYAIDE EXPLORER V2 Speaker Cable 102 SSC Copper 2x0.75mm²
The Oyaide Explorer V2 is part of a new range of 102 SSC Copper speaker cables, simply composed of conductor and insulation. The magic lies in the purity of Copper 102 SSC.
Reference : 15040
8,90 €tax incl.
7,42 € tax excl.
Shipping date: 17-04-2025.
Câble vendu au mètre
Oyaide Explorer V2
Oyaide Explorer V2 Câble haut-parleur Cuivre 102 SSC 2x0.75mm²
The Oyaide Explorer V2 is part of a new range of 102 SSC Copper speaker cables, simply composed of conductor and insulation. The magic lies in the purity of Copper 102 SSC. Its conductors are mounted in parallel and have a multi-layer structure to leave room only for the conductor. Rather than twisting the wires together, the concentric triple-layer structure is used for maximum density, uniform filling of the inner space and to prevent wire deformation.
The insulation is made of Flex PE (Polyethylene) which has both advantageous electrical characteristics and excellent flexibility. Air circulates between the positive and negative conductors for vibration damping and interference prevention. In addition, the Explorer V2 has been designed in a rectangular shape so that it can lie flat and be easily moved around.
The Explorer V2 is the cable with the highest conductivity at Oyaide, and its exceptionally pure Copper makes it a cable with an unbeatable quality/price ratio.
Product typeSpeaker cable
Conductors materialCopper 102 SSC
Number of conductors2
Section2x 0.75mm²
IACS Conductivity102.3%
InsulationPE
ColorWhite
QuantitySold by meter
Diameter (mm)N/A
Length (m)Sold by length
Insulation materialPE
ShieldingNo
Section (mm²)0.75
Ground / ShieldingNo
5 reviews
Respire la qualité
Produit de bonne facture, respire la qualité mais ne peut me prononcer clairement sur le son car utilisé sur du vintage
This review has been posted for OYAIDE EXPLORER V2 Speaker Cable 102 SSC Copper 2x0.75mm²
Très bon câble pour tweeter
Cable chantant tout est beau une gaine plus une gaine neutre, mieux que le CA1 que j'avais qui était un poil trop montant
Eccellente cavetto!
Ho acquistato 1,5m per parte per i miei Pylon Audio Opal 20....che dire...hanno sostituito i Qed Signature Revelation! Appena collegati ho inserito un cd che conosco molto bene e sinceramente non serve davvero spendere più soldi. Questi cavi sono collegati ad un Lector zax 70 integrato da quasi 100 w per canale ma questi piccoli (di dimensioni) cavetti hanno riproposto una scena eccellente, dinamica davvero notevole come anche l'apertura in alto, molto belle le medie tutto ciò nonostante la piccola sezione di 0,75 mm/q ma a me basta visto che ho i diffusori a 1,5 m dall'integrato. Collegati senza terminazioni da ambo le parti, migliori di tutti i cavi avuti in precedenza, davvero non ho mai sentito una musicalità di questa levatura. Li consiglio fortemente a chiunque prima di spenderci soldoni importanti qualunque siano i diffusori e l'amplificazione, al limite valutate sezioni più grandi per misure e diffusori più importanti.
câble HP
Excellent câble pour haut-parleurs, disponible en plusieurs diamètres. Finesse, timbres naturels, aération, bande passante, prouvant que la qualité du cuivre et son tréfilage est primordial dans le résultat final. Les japonais sont d'ailleurs passés maîtres en ce domaine, fournissant beaucoup de grandes marques. Comparé à un OCC, celui-ci est un peu plus chaleureux, plus plein en général, mais sans doute un peu moins aéré et naturel que l'OFC Oyade. En bref, celui-ci se fait totalement oublier à la longue, ce qui prouve son équilibre. Il est d'ailleurs préférable de panacher les fils dans le système, pour ne pas avoir une signature reconnaissable, et inévitable. Un peu comme l'accord des épices en cuisine...
 (4)
oyaide
Makes an excellent interconnect cable at a very good price.
The Oyaide Explorer V2 is part of a new range of 102 SSC Copper speaker cables, simply composed of conductor and insulation. The magic lies in the...
