OYAIDE EXPLORER V2 Speaker Cable 102 SSC Copper 2x2mm²
4.9 / 5
Reference : 9666
21,90 €tax incl.
18,25 € tax excl.
Shipping date: 17-04-2025.
The EXPLORER V2 is a new line of speaker cables made of Copper 102 SSC which is simply composed of conductor and insulation.
The magic lies in the purity of Copper 102 SSC.
Its conductors are mounted in parallel and have a multi-layer structure to leave room for only the driver.
Rather than twisting the wires together, the triple-layer concentric structure is used for maximum density, uniformity of filling of the internal space and to prevent deformation of the wires.
The insulation is made of FLEX PE (Polyethylene) which has both advantageous electrical characteristics and excellent flexibility.
Time limitr flows between the positive and negative conductors for vibration damping and interference prevention.
In addition, the EXPLORER V2 has been designed rectangular in shape so that it can lie flat and be easy to move.
The EXPLORER V2 is the highest conductivity cable that Oyaide has ever created and its exceptionally pure Copper makes it an unmatched value for money cable.
Characteristics :
  • Conductor Copper 102 SSC 3E
  • Conductivity IACS: 102.3%
  • Section: 2mm²
  • Number of Conductors: 2
  • Dimensions: 3.7x8.6mm
  • White Colour
102 SSC Copper Oyaide
Diameter (mm)3.7
Length (m)Sold by length
Number of conductors2
Insulation materialPET
ShieldingNo
Section (mm²)2.00
Ground / ShieldingNo
13 reviews
Great warmth to the sound
A softer type of cable really like it to some systems, no signs of fatigue or sibilance.
Bass I really good
This review has been posted for OYAIDE EXPLORER V2 Speaker Cable 102 SSC Copper 2x2mm²
Incredibilmente performante
Cavo dalle prestazioni eccezionali, assolutamente di livello anche comparato con cavi analoghi di marce blasonate. Raffinato, preciso, assolutamente trasparente. E' un cavo di assoluto riferimento. Ottoni e voci rese con una raffinatezza indescrivibile. Da non perdere!
très bon
utilisé sur le haut parleur juste ce qu'il faut et son jamais fatiguant
c'est du obaide et du pur cuivre
recablage d enceintes
j était un peut inquiet pour le diamètre de seulement 2 mm2. et bien sais super.. aigus sans tonique ni stridente.. doux et soyeux. medium riche de détails .instrument a leurs place. Les voix sont très naturel et chaleureuse dans le bon sens. les graves sont bien tenu. Serré et dynamique. l image stéréo et bien agencée et profonde. Un petit câble qui paye pas de mine qui monter sur mes xo jmr de 1987 redonne toute sa présence sa dynamique. Excellent aussi en câble hp pour la petite chaine de mon amie. Cayn st200 et une paire de Kef et lecteur réseaux sotm m100. jsa ma donné l envie de me mettre a la haute définition.. ;-)Ps: pour des woofer de plus de 150mm préférer les oayde across en 2.8mm2. idem pour une enceinte dépassant les 80w /120w crête. les across sont superbe. pas besoin de dépenser plus si vous rechercher avant tous naturel détails et présence et dynamique contrôlée. du vrais bon matos d audiophile.
 (3)
bon produit - efficace
Bon produit, facile a mettre en place. Très efficace sur mon système moyenne gamme.
Un peu rigide pour un câble de cette taille.
Dans l'ensemble un bon produit.
Oyaide est bien une marque phare du câblage
