SOMMERCABLE MAGELLAN SPK260F HP Coaxial cable OFC 2x6mm² Ø 11.2mm
Reference : 5225
5,90 €tax incl.
4,92 € tax excl.
Last items in stock !
Shipping date: 22-04-2025.
https://www.audiophonics.fr/images2/783/sommer-cable-magellan-spk260f.jpgcoaxial, high flexibility, PVC
SOMMER CABLE - SC-MAGELLAN SPK260F
Long live the wind, live the winter wind ...
You know these songs and music wooers, prompting customers to empty the shelves of stores. For this we also have a suitable cable. A coaxial cable is used where a large conductor cross section is to be combined with a restricted outer diameter,e for example in cable ducts, where the loudspeaker cords rub shoulders with conductors dispersing amounts of electromagnetic disturbances. In principle, these cables are shielded by a tubular envelope composed of braided copper strands, which unfortunately makes the cables stiff and reluctant, hence the impossibility of frequent windings and unwinding. The shielding of the SPK cables is ensured by two windings of copper wires with reciprocal twist, guaranteeing an enormous flexibility and a shielding quality superior to that provided by a usual tubular braid.
For the topthe helical shield is used as the second conductor: the actual cross-sections of the inner conductor and the shield are identical.
BENEFITS:
  • Space saving thanks to the coaxial system
  • Excellent shielding thanks to two twisted coil windings
USE:
  • Building installation
  • Mounting of small connectors (jack, XLR, etc.)
  • High-end hi-fi applications
Specifications:
ConstitutionLI2Y (LS) DY2x6,0mm2
Envelope, diameter 11.2 mm
AWG10
Number of Conductors2 x 6.0mm2
Envelope material, insulation FRNC (mode C)
Copper strands per core 84 x 0.3 mm
Protectiondouble copper coil with reciprocating twist
Optical cover100%
Operating temperature min. -25 ° C
Operating temperature max. 70 ° C
Weight per m196 g
Fire resistance per m 0.44 kWh
Colorblack
Type4.0 mm2
Electrical Specifications:
capacitymetric cond./cond. 130 pF
Odometer Resistance, Conductor3.3 Ohm
Resistance, insulation> 200 MOhm
Diameter (mm)11.2
Length (m)Sold by length
Number of conductors2
Insulation materialPVC
ShieldingYes
Section (mm²)6.00
Ground / ShieldingYes
