SOMMERCABLE MERIDIAN SP215 Speaker Cable OFC Copper 2x1.5mm² Ø6.8mm
This robust cable is specially designed for connecting speakers and technically meets all the requirements. Its copper cores with low oxygen content ensure excellent acoustic characteristics and long service life.
Reference : 5093
2,30 €tax incl.
1,92 € tax excl.
Shipping date: 16-10-2025.
Speaker Cable OFC Copper 2x1.5mm² Ø 6.8mm
SOMMERCABLE MERIDIAN SP215 Câble HP Cuivre OFC 2x1.5mm² Ø 6.8mm
Acousticians are at work: they do not spare the cables, because they never have enough time to take precautions. This robust cable is specially designed for connecting speakers and technically meets all the requirements. Its copper cores with low oxygen content ensure excellent acoustic characteristics and long service life. All versions with PVC sheathing are easy to roll up. The SP215 and SP225 variants are now equipped with very flexible cores made of 0.15 mm copper strands!
Another new feature is the MERIDIAN FG shielded version, for indoor and outdoor installations, with double shielding (copper braid and AL foil) and a halogen-free and flame-resistant outer jacket (IEC 332.3 classification). Due to its composition, this version is not suitable for mobile use.
Benefits :
  • Flexible (PVC and PUR versions) and easily rollable
  • Small diameter
  • Long service life, due to the special blend of outer jacket
  • Attractive price
Applications :
  • Various acoustic installations
  • ELA Technic
  • HiFi system wiring
  • Outside mobile usage  (PUR version)
Product typeSpeaker cable
Constitution(2LIY1.50mm²)Y
Diameter6.8mm
Section16AWG (1.31mm²)
Conductors number2x1.5mm²
InsulationPVC
Copper strand by core84 x 0.15mm
Conductor insulation diameter2.62mm
Operating temperature-30°C / +70°C
Weight per meter78g/m
ColorDark gray
Metric capacity cond/cond150pF
Conductor kilometric resistance< 13 Ohm
Insulatation kilometric resistance> 5 MOhm
Diameter (mm)6.8
Length (m)Sold by length
Number of conductors2
Insulation materialPVC
ShieldingNo
Section (mm²)1.5
Ground / ShieldingNo
2 reviews
I bought these cables to power my new ELAC Debut 2.0 B5.2 speakers in a desktop setup, roughly 1 meter to each speaker, a very short run.
The speakers' manual recommend at least 16 gauge, which is why I picked this cable instead of a smaller one. The double shielding was important for me as they run through the back of the desktop side by side with a lot (*a lot*) of other cables.
They sound great and I'm very happy with the purchase, can recommend.
This review has been posted for SOMMERCABLE MERIDIAN SP215 Speaker Cable OFC Copper 2x1.5mm² Ø6.8mm
rien d autre !
j ai passé des jours , des mois , des années à travailler l acoustique d une pièce de mon sous-sol , mon système par rapport à l origine y a gagné x 100. de faîte aû fil du temps le câble à eu de moins en moins d impacte sur le rendu sonor , au point que ce petit câble et dans mes conditions d écoute est tout simplement fantastique !
ce qui donne sa personnalité à votre système est votre acoustique et rien d autre alors arretez de gaspiller votre argent en Grigris inutiles.
 (7)
This robust cable is specially designed for connecting speakers and technically meets all the requirements. Its copper cores with low oxygen...
