SOMMERCABLE SC-ORBIT 225 MKII Speaker Cable OFC Copper 2x2.5mm²
4.5 / 5
Reference : 5086
4,10 €tax incl.
3,42 € tax excl.
Shipping date: 15-04-2025.
SOMMER CABLE - SC-ORBIT 225 MKII
Hear pushing the grass ...
would be possible with SC-ORBIT. If you value a natural sound, dynamic and high fidelity, choose SC-ORBIT. The loudspeaker is at the end of the circuit, and the means of retransmission of the music are also of enormous importance. You already have a quality loudspeaker: the cable must also fulfill all requirements - and the result is remarkable! This is why we have created this superior quality in the elegant design, because the drivers are often visibly placed - and to facilitate the discreet installation we made them as flat as possible. The very short torsion of the strands of the core brings an improvement in theface conductive braids, ensuring a remarkable purity of reproduction of remarkable sounds. The two conductors being twisted in opposite directions, the cable always resumes its initial shape even after complicated entanglements.
ADVANTAGES:
  • Absolutely neutral transmission quality thanks to special twisted conductors.
  • High flexibility and easy winding thanks to the flexible PVC sheath comparable to rubber
  • Finish distinguished (transparent black sheath)
  • Low resistance values ​​due to special design
USE:
  • Connections for high-end hi-fi speaker systems
  • Indoor wiring for hi-fi speakers and PA systems
  • Fixed installations
  • Stereo connections for vehicles
Specifications:
Envelope, outside diameter PVC 10.2 x 4.8 mm
AWG13
Number of Conductors2 x 2.5 mm2
Copper strands per core 651 x 0.07 mm
Operating temperature min. -30 ° C
Operating temperature max. 70 ° C
Fire resistance per m 0.17 kWh
Weight per m83 g
Colorblack transparent
Type2 x 2.5 mm 2
Electrical Specifications:
Capacity metric cond./cond.<60 pF
Odometer Resistance, Conductor<7.8 Ohm
Resistance, insulation> 10 MOhm
Diameter (mm)4.8
Length (m)Sold by length
Number of conductors2
Insulation materialPVC
ShieldingNo
Section (mm²)2.5
Ground / ShieldingNo
8 reviews
J'aime
Équilibre et douceur. Bon câble pour une écoute relax sans agressivité.
Je le préfère au 4 mm Orbit 240.
This review has been posted for SOMMERCABLE SC-ORBIT 225 MKII Speaker Cable OFC Copper 2x2.5mm²
Franchement top
En remplacement de Deleycon CCA en 2.5 reliant mon Marantz 1050 revisé au WD40 Contact à mes Klipsch RP-600M c’est mieux. Après je ne pense par reconnaître la marque des cordes de guitare de Mark Knopfer
Équilibre !
Utiliser en câble ampli/enceintes et en interne pour le grave/médium des 2 voies que je restaure, il s'avère très naturel, dynamique et équilibré.
Pas de surprise. Ça marche à tout les coups. (Elipson, Focal JM Lab, SIARE)
Une référence pour moi à ce prix.
Sur des 3 voies, je l'utilise pour le grave et je préfère en médium l'Athom Zef mini mais c'est un autre tarif 3 fois plus cher.
Pour les aigus de toute mes restauration, mon chouchou est l'Oyaide explorer.
En conclusion l'Orbit 225 est un très bon câble pour 4€/m.
déçu
déçu
Excellent.
Câble testé et redécouvert recemment, d'où mon commentaire sur celui-ci. Je l'ai écouté comparativement a son cousin Nes 5005 et au Magellan Spk 240 entre autres de prix similaire a savoir 4 euros le mètre. Le matériel utilisé était la partie préampli d'un Cyrus 3 vers un bloc quad 405 sur des Apertura nova. Écoute faite d'abord en mono via le boîtier commutateur dynavox pour une comparaison a/b instantanée, puis validée en stéréo de façon alternée. J'ai trouvé ce câble excellent pour le prix. Belle qualité de timbres alliant richesse et définition. Il surclasse ses compagnons en terme d'espace et d'aération, proposant une image exceptionnelle large et spacieuse, ça fuse de toutes parts sans aucune crispation sur le cd de Léon Parker Belief. Le Spk 240 est aussi vraiment très bon avec peut être un côté un peu plus rond, et plus précis, mais c'est plus feutré, il y a moins d'espace autour des instruments. En ce qui concerne le Nes 5005 il ne se fait pas remarquer côté timbres c'est plutôt neutre. Par contre en stereo l'image se focalise un peu plus comme si l'on était plus proche des instruments. Pour ma part j'apprécie moins mais il faut relativiser cela reste une excellente référence pour le prix.
