SOMMERCABLE SC-ORBIT 240 MKII Speaker Cable OFC Copper 2x4mm²
4.7 / 5
Reference : 5090
5,90 €tax incl.
4,92 € tax excl.
Shipping date: 11-03-2025.
twinned, high-end
SOMMER CABLE - SC-ORBIT 240 MKII
Hear pushing the grass ...
would be possible with SC-ORBIT. If you value a natural sound, dynamic and high fidelity, choose SC-ORBIT. The loudspeaker is at the end of the circuit, and the feedback meansthe transmission of music are also of enormous importance. You already have a quality loudspeaker: the cable must also fulfill all requirements - and the result is remarkable! This is why we have created this superior quality in the elegant design, because the drivers are often visibly placed - and to facilitate the discreet installation we made them as flat as possible. The very short torsion of the strands of the core provides an improvement in the surface of the conductive braids, ensuring a remarkable purity of reproduction of the acute sounds. The two conductors being twisted in opposite directions, the cable always resumes its initial shape even after complicated entanglements.
ADVANTAGES:
  • Absolutely neutral transmission quality thanks to special twisted conductors.
  • High flexibility and easy winding thanks to the flexible PVC sheath comparable to rubber
  • Finish distinguished (transparent sheath)
  • Low resistance values ​​due to special design
USE:
  • Connections for high-end hi-fi speaker systems
  • Indoor wiring for hi-fi speakers and PA systems
  • Fixed installations
  • Stereo connections for vehicles
Specifications:
Envelope, outside diameter PVC 12 x 5.9 mm
AWG11
Number of Conductors2 x 4.0 mm2
Copper strands per core 1036 x 0.07 mm
Operating temperature min. -30 ° C
Operating temperature max. 70 ° C
resistanto the fire by m0.21 kWh
Weight per m121 g
Packaging, packaging unitroll 100 m
Packaging, packaging unitcrown 25 m
ColorTransparent
Type2 x 4.0 mm 2
Electrical Specifications:
Capacity metric cond./cond.<55 pF
style = "font-size: small;"><4.5 Ohm
Resistance, insulation> 10 MOhm
Diameter (mm)5.9
Length (m)Sold by length
Number of conductors2
Insulation materialPVC
ShieldingNo
Section (mm²)4.00
Ground / ShieldingNo
22 reviews
un produit suivi : c'est bien pratique de pouvoir acheter un complément du même câble quelques années plus tard.
This review has been posted for SOMMERCABLE SC-ORBIT 240 MKII Speaker Cable OFC Copper 2x4mm²
Excellent câble HP
Je donne un second avis
Maintenant que mes enceintes sont rodées je leur trouve une scène sonore plus étriquée qu'avant et des graves secs mais moins puissants qu'avec les elecaudio. Malgré tout pour le prix ça reste d'excellents câbles HP. Je recommande pour des systèmes dont le grave est brouillon et mal maîtrisé.
Excellent câble HP
Il remplace l'elecaudio hp250 . Ce sommercable est meilleur à tous les niveaux. Plus de clarté, musique moins brouillonne, grave plus secs et tout aussi profonds. Je suis très étonné, la différence est flagrante. Mes enceintes sont encore en rodage et l'amélioration est sensible. Système : Davis balthus 90 et marantz pm8006
Excellent câble !
A ce tarif là, foncez, vous ne serez pas déçu.
Essai longue durée du sommercable orbit 240 MKII
Après plusieurs essais dans ma configuration : Ampli Yamaha AS-1200 et Yamaha CD S 1000 +Enceint Récital Define, il s'avère que le message musical est un peu brouillon tout cela en nuances bien sûr.
En connectant mon câble Triangle Opéra tout est revenu comme j'aime. Il n'y qu'en essayant sur son propre système que l'on se rend compte si le câble testé corresponds a vos souhaits....
 (3)
