The BC44NET cable from ddHiFi is fitted with gold-plated 4.4mm jack connectors on both ends to provide foolproof protection against corrosion and oxidation. At 15cm long, it's ideal for short interconnects, such as connecting a DAP.
It boasts excellent build quality, with a total of 8 litz-structured OCC copper conductors insulated separately by a double HDPE and PVC jacket before being braided together. Finally, each 4.4mm jack connector, in addition to being gold-plated, has a titanium body for exceptional durability.
Product type | 4.4mm jack interconnect cable |
Connectors | 2x Jack 4.4mm |
Conductors material | OCC Copper |
Cable structure | Litz wire |
Section | 8x 0.162mm² (25.4 AWG) |
Shielding | Ground connected to both connectors |
Insulation | NUC HDPE (Japon) SoftFlex PVC (USA) |
Connectors body material | Titanium alloy |
Connector contact plating | Gold |
Length | 15cm |
Weight | 20g |
Package | Sold by unit |
Length (m) | 0.15 |
Shielding | Yes |
Section (mm²) | 1.3 |
Connector | Jack 4.4mm |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
