Male Jack 3.5mm to Female Jack 3.5mm Copper 102SSC Silver / Rhodium Plating 2.5m
This superb high-end cable is equipped with a 3.5mm male jack connector on the one hand and a 3.5mm female jack connector on the other. It will be particularly useful to take advantage of an extension of a headphone cable that is too short by acting as an extension cable. The materials used for this HPSC-35J contribute to a significant improvement in reliability and sound quality.
The cable conductors are made of high-purity 102 SSC Copper and each connector is plated with Silver and Rhodium to ensure excellent conductivity and durability. The conductors are insulated with TPE sheath and 102 SSC 100/0.12 shielding to significantly reduce unwanted interference. The cable is assembled with a high quality SS-47 weld. Unlike conventional soldering, which uses 3N (99.9%) of pure tin, the SS-47 uses 4N, i.e. 99.993% of pure tin, thus excluding a maximum of impurities. In addition, this solder also contains 4.7% Silver and 1.7% Copper.
Product type | Jack cable |
Connectors | 1x Male Jack 3.5mm 1x Female Jack 3.5mm |
Length | 2.5m |
Conductor material | Copper 102SSC 60 / 0.08 |
Connectors plating | Silver 1.5µ + Rhodium 0.3µ |
Insulation | TPE |
Shielding | 102 SSC 100/0.12 |
Insulation resistance | 20°C / 10MΩ-km |
External sheath | Braided silk |
Color | Cable : Black and white Connector : Silver |
Cable diameter | 4mm |
Connectors diameter | Male Jack 3.5mm : 8.5mm Female Jack 3.5mm : 9.3mm |
Length (m) | 2.5 |
Shielding | Yes |
Section (mm²) | 0.0810 |
Connector | Jack 3.5mm |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
