SOMMERCABLE GOBLIN Jack 3.5mm Stereo Cable 5m
Reference : 4654
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 25-04-2025.
Mini-JACK 3.5" Stereo modulation cable built on the SOMMERCABLE GOBLIN cable, which is distinguished by its thinness and flexibility, as well as its sophisticated shielding providing high resistance to crushing and traction.
Black cable, very sober, ideal for a professional use in studio, or within the framework of a private installation which one wishes discrete and powerful. Mini-JACK 3,5" HICON 3-pole stereo connectors plated with 24k gold with locking system.
https://www.audiophonics.fr/images2/4648-4652_SOMMERCABLE-GOBLIN-JACK3.5M-JACK3.5M_1.jpg
Characteristics:
  • Flexible cable with an external diameter of 4.6mm
  • High tensile strength due to its double shielding and special PVC sheath
  • High linearity of acoustic retransmission due to the composition of the conductor pairs and the special wiring technique of the copper cables
  • 100% Shielding (Metallized Strip + Copper Helical Coil)
  • 24k Gold plated Jack 3.5mm Hicon connectors
  • Total length: 5m
Specifications:
Constitution(2LI2Y0,14mm2)(ST)DY
Outer sheath / diameterPVC / 4.6mm
Section26AWG
Conductors: 2*,14 mm2
Copper strands per core18*0,1mm
InsulationPE 0.92mm
ProtectionTinned copper helical coil + metallized strip
Optical Coverage100%
Operating temperature range-30°C / +70°C
Fire resistance / m0,1kWh
Metric capacity conductor / conductor65 pF
Metric Capacity Conductor / Screen120 pF
Conductor kilometric resistance< 148 Ohm
Shielding kilometric resistance30 Ohm
Insulation kilometric resistance> 1 GOhm
https://www.audiophonics.fr/images2/4648-4652_SOMMERCABLE-GOBLIN-JACK3.5M-JACK3.5M_2.jpg
Length (m)5.0
ShieldingYes
Section (mm²)0.14
ConnectorJack 3.5mm
