Great cable! Solid build. Can only recommend. As usual, Audiophonics is a really good shop!
SOMMERCABLE GOBLIN Jack 3.5mm Stereo Cable 1m
Jack 3.5mm stereo modulation cable built on the Sommercable Goblin cable, which is distinguished by its thinness and flexibility, as well as its sophisticated shielding providing high resistance to crushing and traction.
Black cable, very sober, ideal for a professional use in studio, or within the framework of a private installation which one wishes discrete and powerful. Jack 3.5mm Hicon 3-pole stereo connectors plated with 24k gold with locking system.
Characteristics:
Specifications:
Constitution | (2LI2Y0,14mm2)(ST)DY |
Outer sheath / Diameter | PVC / 4,6mm |
Section | 26 |
Conductors | 2 x 0,14 mm2 |
Number of strands per core | 18 x 0,10 mm |
Conductors insulation | PE 0,92 mm |
Protection | Tinned copper helical coil + metallized strip |
Optical covering | 100 % |
Operating temperature range | Min. -30 °C / Max. 70 °C |
Fire resistance / m | 0,10 kWh |
Conductor/Conductor metric capacitance | 65 pF |
Conductor/Screen metric capacitance | 120 pF |
Conductor kilometric resistance | < 148 Ohm |
Shielding kilometric resistance | 30 Ohm |
Insulation kilometric resistance | > 1 GOhm |
Length (m) | 1.0 |
Shielding | Yes |
Section (mm²) | 0.14 |
Connector | Jack 3.5mm |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
