This Topping cable is a double trigger cable, specifically designed for use with the brand's B100/B200 mono amplifiers. It consists of a 3.5mm stereo jack connector to 2 3.5mm stereo jack connectors. Perfect for pairing the E70 or E70 Velvet DAC with two B100s, for example. With a length of 2m, it allows you to position your devices freely in your room.
Please note that the soldered joints on this cable have certainly been customized by Topping. This cable may not be compatible with other brands.
Product type | Dual trigger cable |
Length | 2m |
Connectors | 1x 3.5mm stereo male jack 2x 3.5mm stereo male jacks |
Color | Black |
Package | 1x Topping dual trigger cable |
Length (m) | 2.0 |
Shielding | NC |
Section (mm²) | N/A |
Connector | Jack 3.5mm |
Contacts Material (Connector) | Copper Alloy |
Conductors material (Cable) | Copper Alloy |
Conductors Plating (Cable) | None |
