Male Mono RCA to Male Mono Jack 3.5mm Gold Plated 1.8m
This cable consists of a mono mâle RCA connector and a mono mâle 3.5mm jack. It may therefore allow you to connect some mono devices with these connections, such as the mono amplifier Audiophonics TPA-M50 which only has a 3.5mm mono jack connector at its input. The cable is also compatible with the Coaxial input in 3.5mm Jack format from SMSL AD18. In addition, the cable connectors are gold-plated to ensure good conductivity and oxidation resistance.
Product type | Male mono Jack 3.5mm to male mono RCA cable |
Length | 1.8m |
Connectors plating | Gold |
Color | Black |
Length (m) |
Shielding |
Section (mm²) |
Connector |
Conductors material (Cable) |
Conductors Plating (Cable) |
