By buying this product you get 31 loyalty points
Neotech's NEVD cables are carefully designed especially for the transmission of digital audio signals. The main characteristic of the digital audio signal is the transmission of very high frequencies. Therefore, the brand has particularly worked on minimizing the signal loss.
The NEVD-1001 is an excellent coaxial cable with an impedance of 75Ω, offering a wide bandwidth to reduce jitter and ensure maximum resolution. The cable benefits from an exceptional design, with a OCC Silver conductor and a particularly effective quad shielding consisting of Polyethylene foam, Copper-Mylar foil, microporous PTFE and SP-OFC braid.
Product type | Coaxial cable |
Connectors | Male RCA (Coaxial) |
Length | 2m |
Impedance | 75Ω |
Conductor | OCC Silver |
Contacts plating | Gold |
Quad Shielding | Polyethylene foam Cu-Mylar foil Microporous PTFE Braided SP-OFC |
Length (m) | 2.0 |
Shielding | Yes |
Section (mm²) | N/A |
Connector | Coaxial |
Conductors material (Cable) | Silver |
Conductors Plating (Cable) | Gold |
