NEOTECH NEVD-2001 Coaxial Cable 75 Ohm Silver Shielded 1m
The NEVD-2001 is an excellent Coaxial cable with an impedance of 75Ω, offering a wide bandwidth to reduce jitter and ensure maximum resolution. The cable benefits from an exceptional design, with a pure Silver conductor and a particularly effective quad shielding.
Reference : 15348
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 15-04-2025.
Neotech NEVD-2001
Neotech NEVD-2001 Câble Coaxial 75Ω Argent Blindé 1m
Neotech's NEVD cables are carefully designed especially for the transmission of digital audio signals. The main characteristic of the digital audio signal is the transmission of very high frequencies. Therefore, the brand has particularly worked on minimizing the signal loss.
The NEVD-2001 is an excellent Coaxial cable with an impedance of 75Ω, offering a wide bandwidth to reduce jitter and ensure maximum resolution. The cable benefits from an exceptional design, with a pure Silver conductor and a particularly effective quad shielding consisting of Polyethylene foam, Copper-Mylar foil, microporous PTFE and SP-OFC braid.
Product typeCoaxial cable
ConnectorsMale RCA (Coaxial)
Length1m
Impedance75Ω
ConductorPure Silver
Contacts platingGold
Quad ShieldingPolyethylene foam
Cu-Mylar foil
Microporous PTFE
Braided SP-OFC
Length (m)1.0
ShieldingYes
Section (mm²)N/A
ConnectorCoaxial
Conductors material (Cable)Silver
4 reviews
De la transparence…
Je confirme les commentaires précédents, ce câble de par sa conception UPOCC est hyper transparent, vous allez obtenir un son en 3D avec une scène sonore étagée. Compter une semaine de rodage. Bande passante énorme. À recommander…
This review has been posted for NEOTECH NEVD-2001 Coaxial Cable 75 Ohm Silver Shielded 1m
Un coaxial haut de gamme à un tarif abordable
Je suis fan de la marque, j’ai découvert avec le Câble Nemoi 3220 cette marque, j’apprécie cette restitution douce, neutre, ouverte et avec un aigu très clair. Ce câble relie mon lecteur de CD Denon et mon DAC Gustard R26.
Le résultat me paraît apporter de la douceur, un bon niveau de détails en particulier sur les fréquences élevées. On retrouve le côté translucide et clair propre à la marque. J’ai sur d’autres sources le câble coaxial Audiophonics Canare qui a la particularité d'inclure des connecteurs CANARE C5F, certifiés 75Ω conseillé par Audiophonic. Ce dernier me semble plus dynamique et neutre (ni doux, ni sec), son ouverture me semble moins bonne, notamment en largeur. Ce coaxial Néotec est un bon investissement pour avoir une connexion numérique entre des composants qui permettent d’exploiter son potentiel. J’utilise la version USB qui est dans le même style.
very good
I've change chord clearway with nevd2001. The sound has more details on medium and high freqv. A good upgreat. I recommend!
Trés bon cable
Le câble "Neotech NEVD-2001" est également disponible au mètre (ou plus exactement au 25cm) chez hificollective. Dommage que Audiophonics ne le propose pas aussi.
Voilà ce que j'ai fait:
- 1.5m de câble "Neotech NEVD-2001"
- Connecteur RCA DG-201 ou DG-202.
- 40 Ferrites "Farnell 351-7025" placées sur toute la longueur du câble.
Résultat:
- J'obtiens un son clair, doux et très précis.
- Le résultat est meilleur que le câble Esprit-Audio à 500 euros fournit par TotalDac, ou il subsistait une petite dureté.
- Je l'utilise comme liaison digital entre mon OPPO 105D et un DAC D1-Single...
Peut-être d'autre personne pourrait constater le même effet?
Alain
The NEVD-2001 is an excellent Coaxial cable with an impedance of 75Ω, offering a wide bandwidth to reduce jitter and ensure maximum...
