OYAIDE DST-75R V2 SPDIF Coxial Cable
The OYAIDE DST-75R V2 cable is a very high quality 75Ω RCA coaxial cable with a unique architecture and assembled with high-end connectors. These RCA connectors feature Silver + Rhodium plating for unrivalled conductivity and transmission.
Reference : 18484
85,00 €tax incl.
70,83 € tax excl.
Shipping date: 15-04-2025.
OYAIDE DST-75R V2
Coaxial Cable RCA SPDIF 75 Ohm 102SSC Rhodium Plated 0.7m
OYAIDE DST-75R V2 Coaxial Cable RCA SPDIF 75 Ohm 102SSC Rhodium Plated 0.7m
The DST-75R V2 is an RCA coaxial cable developed for music lovers seeking optimum lossless quality and full-bandwidth neutrality for great musicality above all else.
Oyaide builds every cable the same way, with optimized engineering solutions applied to materials and manufacturing processes, complemented by meticulous craftsmanship.
This cable features a double layer of shielding against interference; copper foil and 102SSC braided copper, as well as insulation thanks to a "Cordell" structure. The cable conductor is made of 102SSC copper for precise, clear signal transmission. The connection to the RCA connectors is made using SS-47 acoustic solder, a lead-free silver solder.
Product typeRCA 75 Ohm coaxial cable
Cable structureSingle-strand
Conductor material102SSC Copper (1.05mm² - AWG17)
InsulationHigh-density polyethylene
ShieldingCopper foil
Contacts materialCopper
Contact platingSilver + Rhodium
Total cable diameterØ6.6mm
ColorWhite
Cable length0.7m
Package1x OYAIDE DST-75R V2 cable
Length (m)0.7
ShieldingYes
Section (mm²)1.05
ConnectorCoaxial
Profond, précis, aéré !
Excellent câble coaxial Oyaide. Je l’ai connecté à un lecteur CD Tonewinner TY-30 en utilisant le dac de l’ampli après avoir essayé un dac externe (je n’entre pas dans le détail des marques car j’ai essayé plusieurs amplis). J’avais d’abord essayé divers câbles RCA mais malgré une belle sonorité les basses n’étaient pas assez détourées et se fondaient un peu avec le bas médium. C’est un peu la tendance du lecteur TY-30. Aigus et médiums très lisses et aérés mais à mesure que l’on descend dans le spectre, le son semble devenir de plus en plus analogique. Je trouve que c’est un atout pour un lecteur CD mais il faut trouver le bon câble pour mettre en valeur ses particularités. J’ai donc essayé un câble coaxial Mogami avec connecteurs Canare, la sonorité est devenue légèrement plus vive avec des basses un peu plus tendues et précises. J’ai ensuite essayé le câble coaxial Oyaide DST-75R V2. Avec ce câble la scène s’est ouverte en largeur et surtout en profondeur avec de l’espace entre les instruments. Une sonorité plus aérée dans l’ensemble du spectre. Des aigus fins, détaillés sans dureté ou acidité. De beaux médiums distincts et des basses un peu plus tendues, précises et profondes. Rapides et percutantes. Finalement, ce câble Oyaide est vraiment très bien conçu car il met parfaitement en valeur la musique et, dans ce cas précis, les qualités du Tonewinner TY-30.
This review has been posted for OYAIDE DST-75R V2 Coaxial Cable RCA SPDIF 75 Ohm 102SSC Rhodium Plated 0.7m
The OYAIDE DST-75R V2 cable is a very high quality 75Ω RCA coaxial cable with a unique architecture...
