The OYAIDE DST-75R V2 cable is a very high quality 75Ω RCA coaxial cable with a unique architecture and assembled with high-end connectors. These RCA connectors feature Silver + Rhodium plating for unrivalled conductivity and transmission.
The DST-75R V2 is an RCA coaxial cable developed for music lovers seeking optimum lossless quality and full-bandwidth neutrality for great musicality above all else.
Oyaide builds every cable the same way, with optimized engineering solutions applied to materials and manufacturing processes, complemented by meticulous craftsmanship.
This cable features a double layer of shielding against interference; copper foil and 102SSC braided copper, as well as insulation thanks to a "Cordell" structure. The cable conductor is made of 102SSC copper for precise, clear signal transmission. The connection to the RCA connectors is made using SS-47 acoustic solder, a lead-free silver solder.
Product type | RCA 75 Ohm coaxial cable |
Cable structure | Single-strand |
Conductor material | 102SSC Copper (1.05mm² - AWG17) |
Insulation | High-density polyethylene |
Shielding | Copper foil |
Contacts material | Copper |
Contact plating | Silver + Rhodium |
Total cable diameter | Ø6.6mm |
Color | White |
Cable length | 1.3m |
Package | 1x OYAIDE DST-75R V2 cable |
Length (m) | 1.3 |
Shielding | Yes |
Section (mm²) | 1.05 |
Connector | Coaxial |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
