VIABLUE NF-75 Digital RCA Coaxial Cable Silver Plated Shielding 15m
By buying this product you get 51 loyalty points
Reference : 3328
513,99 €tax incl.
428,32 € tax excl.
Viablue NF-75 RCA cables are high-end digital coaxial cables with ideal electrical characteristics that allow for correct and error-free digital signal transmission. In addition to a basic impedance of 75 Ohm, this cable also includes a polyethylene dielectric insulation and a silver-plated shield. These technical features ensure extremely low resistance values and maximum transmission quality of digital signals.
The Viablue Silver Shield provides NF-75 RCA cables with 100% shielding, covering the entire cable. This shield is composed of an aluminum foil and a silver plated braided shield. The RCA NF-75 cables are assembled with gold plated, Teflon insulated RCA XLS Viablue plugs that can be tightened onto the RCA terminals by rotating the socket. These plugs provide an extremely solid clamping and resistance-free contact. In addition, induced currents that may occur between the conductor and the shielding are eliminated by the ferrite cores placed at the ends.
Characteristics:
  • Outer diameter: 9mm
  • Connectors: T6s RCA plugs
  • Impedance: 52pF/M / 75 Ohm
https://www.audiophonics.fr/images2/106/106_viablue_2.jpg
https://www.audiophonics.fr/images2/106/106_viablue_1.jpg
Length (m)15.0
ShieldingYes
Section (mm²)N/A
ConnectorCoaxial
Conductors Plating (Cable)NC
