By buying this product you get 26 loyalty points
VIABLUE NF-75 Digital RCA Coaxial Cable Silver Plated Shielding 5m
ViaBlue NF-75 RCA cables are high-end digital coaxial cables with ideal electrical characteristics that allow for proper and error-free digital signal transmission. In addition to a base impedance of 75 ohms, this cable also includes a polyethylene dielectric insulation and a silver-plated shield. These technical features ensure extremely low resistance values and maximum transmission quality of digital signals.
The ViaBlue Silver Shield provides NF-75 RCA cables with 100% shielding, covering the entire cable. This shield is composed of an aluminum foil and a silver plated braided shield. The NF-75 RCA cables are assembled with gold-plated, Teflon-insulated XLS ViaBlue RCA plugs that can be tightened onto the RCA terminals by rotating the socket. These plugs provide an extremely tight fit and resistance-free contact. In addition, induced currents that may occur between the conductor and the shielding are eliminated by the ferrite cores on the ends.
Characteristics:
Outer diameter: 9mm
Connectors: T6s RCA plugs
Impedance: 52pF/M / 75 Ohm
Length (m) | 5.0 |
Shielding | Yes |
Section (mm²) | N/A |
Connector | Coaxial |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | NC |
