The optical cable Pangea Audio First SE uses a multi-core plastic optical fiber.
A feature that allows it to overcome the limitations caused by the dispersion phenomenon that occurs regularly in single clore optical cable.
To offer optimal performance, the endings of First SE cables were polished using an ultra-fine abrasive for a robust extremity, fine and as transparent as possible.
This process gives much better results than the traditional method of hot-plating which comprises heating the termination for the flattening and secure the cap connector.
Type | Digital cable |
terminations | Optical / Optical |
Length | 3m |
Sheath | Black |
Length (m) |
Shielding |
Section (mm²) |
Connector |
Conductors material (Cable) |
Conductors Plating (Cable) |
