VIABLUE H-FLEX Digital Cable Optical Toslink to Mini-Toslink 3.5 1m
Reference : 9817
91,99 €tax incl.
76,66 € tax excl.
ViaBlue Toslink H-Flex cables are high-end optical audio cables that transmit digital signals using fiber optic technology. In this type of technology, the electrical interference has no influence on the transmission quality.
Toslink H-Flex cables provide professional-quality optical connectivity between high-end components such as amplifiers, CD / DVD decks, and more.
The design of a special fiber for the waveguide used in Toslink H-Flex cables ensures maximum efficiency of the light source.
These cables possess a great flexibility thanks to several machining processes used for the application of insulating layers made of different materials, which allows very high curvature angles without increasing the rate of attenuation.
The high quality waveguide is protected by a special compound of flexible plastic materials.
Another layer of a very thin and very hard plastic material directly covers this compound to stabilize and fix the sensitive internal structure.
Finally, a thick outer sheath protects these three internal layers from crushing and deterioration.
Toslink H-Flex cables are covered with a Cobra ViaBlue braid thatr offers additional exterior protection and an impressive exterior appearance.
Features:/ Strong>
  • Diameter: 9 mm
  • Diameter of the fiber: 1 mm
  • Connectors: T6s Toslink and mini Toslink 3.5mm
  • Fiber: Polymethyl Methacrylate
  • Length: 1m
Length (m)1.0
ShieldingNo
Section (mm²)N/A
ConnectorOptical Mini-Toslink
ConnectorOptical Toslink
Conductors material (Cable)Optical Fiber
