VIABLUE H-FLEX Digital Optical Cable Mini-Toslink 0.50m
4.0 / 5
Reference : 6961
79,99 €tax incl.
66,66 € tax excl.
Shipping date: 18-04-2025.
ViaBlue Toslink H-Flex cables are high-end optical audio cables that transmit digital signals using fiber optic technology. In this type of technology, the electrical interference has no influence on the transmission quality. Toslink H-Flex cables provide professional-quality optical connectivity between high-end components such as amplifiers, CD / DVD decks, and more.
The design of a special fiber for the waveguide used in Toslink H-Flex cables ensures maximum efficiency of the light source. These cables possess a great flexibility thanks to several machining processes used for the application of insulating layers made of different materials, which allows very high curvature angles without increasing the rate of attenuation.
The high quality waveguide is protected by a special compound of flexible plastic materials. Another layer of a very thin and very hard plastic material directly covers this compound to stabilize and fix the sensitive internal structure. Finally, a thick outer sheath protects these three internal layers from crushing and damage.
The CToslink H-Flex cables are covered with a Cobra ViaBlue braid that offers protectionand an impressive exterior appearance.
Features:
  • Diameter: 9 mm
  • Diameter of the fiber: 1 mm
  • Connectors: T6s mini Toslink
  • Fiber: Polymethyl Methacrylate
https://www.audiophonics.fr/images2/6961/6961_VIABLUEHFLEXMINITOSLINK_1.jpg
Length (m)0.5
ShieldingNo
Section (mm²)N/A
ConnectorOptical Mini-Toslink
Conductors material (Cable)Optical Fiber
Très bon mais assez rigide.
Très bon son, équilibré, détaillé, sensuel.
Par rapport à mon précédent câble optique (un hitachi à 15 euros), la différence est très nette !
Avec ce Viablue, on ressent les intentions des artistes, les émotions. Extinctions de notes, nuances, matière, dynamique, harmoniques, tous est bien placé, propre et net.
On ressent aussi le silence derrière la musique, ce qui la rend plus palpable, présente, spacialisée.
Bref que du bon.
Je l'utilise entre la TV et le SMSL AD18, le son est transfiguré !
Beaucoup de détails sonores apparaissent, c'est très agréable.
je me surprends même à écouter des clips du Top 50 !
Du coup, écouter des concerts à la télé devient vraiment intéressant mais la prise de son doit être soignée, sinon le Viablue mettra la médiocrité en évidence.
Par contre il est assez rigide, ça surprend.
Du coup, c'est son rayon de courbure qui décide de la position de l'AD 18 !
Dans certains cas, si vos appareils sont légers, il faudra les bloquer pour que la rigidité du câble ne les déplace pas.
This review has been posted for VIABLUE H-FLEX Digital Optical Cable Mini-Toslink 0.50m
