VIABLUE H-FLEX Digital Optical Toslink Cable 1m
4.7 / 5
Reference : 905
90,00 €tax incl.
75,00 € tax excl.
Shipping date: 16-04-2025.
Toslink H-Flex ViaBlue cables are high-end optical audio cables that transmit digital signals using optical fibre technology. In this type of technology, electrical interference has no influence on the quality of the transmission. Toslink H-Flex cables provide a professional quality optical connection between high-end components such as amplifiers, CD/DVD decks, etc.
 The special fibre design for the waveguide used in Toslink H-Flex cables ensures maximum light source efficiency. These cables have a very high flexibility thanks to several machining processes used for the application of layers of insulation made of different materials, which allows very accentuated bending angles without increasing the attenuation rate. In the case of very large curvatures, the H-Flex optical fibre cable will transmit your data without any alteration.
The high quality waveguide is protected by a special flexible plastic compound. Another layer of very thin yet very hard plastic directly covers this compound to stabilize and fix the sensitive internal structure. Finally, a thick outer sheath protects these three inner layers from crushing and damage.
âToslink H-Flex cables are covered with a Cobra ViaBlue braid which provides additional external protection and an impressive external appearance. Equipped with Toslink H-Flex ViaBlue metal plugs, the ends of Toslink H-Flex cables are perfectly protected. The metal end caps up to the end guarantee stability over time and durable protection of the bare waveguide.
https://www.audiophonics.fr/images2/107/107_VIABLUEHFLEX.jpg
https://www.audiophonics.fr/images2/107/107_viablue_cable_toslink.jpg
Length (m)1.0
ShieldingNo
Section (mm²)N/A
ConnectorOptical Toslink
Conductors material (Cable)Optical Fiber
10 reviews
Bonne qualité, bien travaillé, rien à dire.
This review has been posted for VIABLUE H-FLEX Digital Optical Toslink Cable 1m
Fabuleux
Branché entre un Nuprime Ida-8 et sa boîte d'allumette le D-Sream Primo HD, enterre tous c concurrents... très musical, précis, dynamique sans fatigue comme certains hdg... un véritable régal.
Joli cable
La qualité est visible, belles finition, livraison rapide. Très bon produit
exelent comparé a du coax argent
fixer sur ma platine cd musical fidelity x-ray et mon dac audio gd r28(r2r) j ai comparer l écoute entre coax et tos link. la sais autre chose..la spatialité la dynamique le naturel ..bref tout y est. .seul le grain et le piqué donne avantage a mon coax oayde.. pour prêt de 5/6 fois le prix. Apres le changement des embase rca avec des wbt argent .ont verra si sa reste aussi tenu dans la différence. mais sais déjà pas mal.. cet marque et peut être pas trop connue.. mais elle a de très bon résultat partout ou des ami l utilise.. a ne pas manquer.. pour un rapport q/prix très intéressant.. et made in allemande.
Qualité et musicalité excellentes
Le câble optique VIABLUE H-FLEX est très rigide et c’est tant mieux. Cela évite de plier la fibre optique en le manipulant. Il suffit de prendre une longueur de 2,50 m pour ne pas avoir de problème de branchement. A ce propos, les connecteurs sont d’excellent qualité, la fixation est parfaite, cela ne branle pas comme beaucoup de câble bas de gamme, voire haut de gamme.
D’un point de vue musical, la musique passe intégralement avec toute sa dynamique et tout son naturel. Aucune dureté, même sur de grosses formations orchestrales (test effectué sur des enregistrements de référence). L'image stéréo est en 3D. En résumé ce câble est meilleur que bien des concurrents vendus plus chers. Merci à Audiophonics de vendre des produits bien sélectionnés de très bonne qualité.
Le câble le coaxial CANARE est aussi une référence.
