1877PHONO GOLD RUSH AU/AG Cable RCA / RCA Stereo 24K Gold Plated PC-OCC Copper Silver 1m50
The Gold Rush RCA - RCA cable represents all the know-how of the Canadian brand Zavfino 1877Phono. This cable, designed to accompany prestigious vinyl decks, offers a selection of the finest components to serve your music.
By buying this product you get 104 loyalty points
Reference : 13268
1 049,00 €tax incl.
874,17 € tax excl.
Shipping date: 24-04-2025.
1877Phono Gold Rush AU/AG
RCA / RCA Stereo Cable 24K Gold Plated PC-OCC Copper Silver 1m50
1877Phono Gold Rush AU/AG Câble RCA / RCA Cuivre PC-OCC Argent Plaqué Or 24k
The Gold Rush RCA - RCA cable represents all the know-how of the Canadian brand Zavfino 1877Phono. This cable, designed to accompany prestigious turntables, offers a selection of the finest components to serve your music.
PC-OCC Copper, Silver and 24K Gold Plating
1877Phono integrates the best conductors in its cable to ensure perfect signal transmission. These cables contain single-crystal PC-OCC copper and 99.9998% pure silver conductors. The conductors are also 24K gold plated. This incredible design provides perfect conductivity for rich, detailed, accurate reproduction.
1877Phono Gold Rush Argent Cuivre PC-OCC plaquage Or 24k
1877Phono Gold Rush H-Wound
H-Wound
With over 18 years of cable manufacturing experience, Zavfino 1877Phono has developed a new technique to tighten the stranded wire firmly around a solid core center conductor. This unique technique eliminates the skin effect that damages the quality of the timbres and the natural of the restitution. For this process, the brand uses a custom-made transformer wire stranding machine with modified gears. Thus, it is able to create windings more slowly but with a much tighter pitch, without the strands overlapping. Where most stranding machines can only produce windings of up to 300 torsions per meter, the patented 1877Phono H-Wound machine allows windings of 16,000 torsions per meter.
The manufacturer adds to this the Zero Strand Loss technique which protects the conductors against damage during stripping and termination. Therefore, by ensuring that each core is perfect, flawless, the brand can guarantee that each core is 100% identical. These techniques allow these cables to offer incredible timbre precision, a magnificent sound image and an extremely rich reproduction.
Deep cryo Treatment
Each driver undergoes a Deep Cryo treatment. This consists in cooling the conductors between -186°C and -196°C. To define the exact temperature at which conductors must descend, 1877Phono studies the purity, size and molecular structure of each conductor. This treatment allows to obtain more convincing silences, to improve the bandwidth or even the dynamics
1877Phono Gold Rush traitement deep cryo
1877Phono Gold Rush Ultra Sonic traitement
UltraSonic 7 Treatment
This is a two-step process. First, the bare conductor is passed through a ceramic die in an ultrasonic cleaning chamber. This process removes impurities and imperfections from the surface of the wire, down to the molecular level. Once each wire is processed, they are bundled together for a new treatment. During this second stage, the voltage is increased while remaining below the threshold of the conductor. This adjustment makes it possible to obtain a fast break-in in addition to the 30 to 40 hours of signal and/or current that each cable receives. The Ultra Sonic 7 and Deep Cryo treatment prepare the cable to break-in in days rather than months at the user's site.
Graphene Insulation
For conductor insulation, 1877Phono uses a special process, based on Graphene, an allotrope offering excellent electrical, mechanical and chemical characteristics. To develop this process, the brand worked for two years with an American Graphene polymer research company. This treatment provides much better protection against electromagnetic interference. In addition, Graphene's high thermal deformation capacity strengthens the dielectric by 30% to ensure identical performance for decades to come. Finally, Graphene creates a 100% anti-corrosive barrier that prevents oxygen from penetrating the shielding and conductors. This isolation ensures both a perfectly closed electromagnetic field blocking all interference, as well as greater durability.
The Gold Rush cable also benefits from a second dielectric level using PTFE and PET to perfect its insulation. Finally, the cable also has double shielding made of Mylar Aluminium and Silver Plated Braided Copper foil.
1877Phono Gold Rush Blindage Graphène
A perfectly finished cable
All Gold Rush elements benefit from the same connection quality. For example, the RCA connector contacts are made of 24k gold-plated copper, the ground wire cables are made of SPOFC copper and the ground wire clamps are made of 24k gold-plated copper. The splitters are made of anodized Aluminium and the cable sheath is made of PET monofilament with anti-static fiber, gold color.
Cable typeMale RCA to male RCA cable with ground wires for turntables
Length1.5m
Conductors material24k Gold Plated Mono Cristal PC-OCC Copper + Silver
RCA Connectors material24k Gold plated Copper
Ground wires conductorsSPOFC Copper
Ground connectors material24k Gold plated pure Copper
InsulationGraphene
PTFE / PET
ShieldingAluminium Mylar Foil
Silver plated braided Copper
TreatmentsDeep Cryo
H-Wound
UltraSonic 7
SheathMono-filament PET with anti-static fiber
ColorGold
Length (m)1.5
ShieldingYes
Section (mm²)N/A
ConnectorRCA
Conductors material (Cable)Silver
Conductors Plating (Cable)Gold
The Gold Rush RCA - RCA cable represents all the know-how of the Canadian brand Zavfino 1877Phono. This cable, designed to accompany prestigious...
