1877PHONO THE MAHONE RCA Phono RCA - RCA Cable + Ground wire 1.5m
The "THE Mahone RCA" cable from the famous Canadian 1877 PHONO brand allows you to connect your phono player to your phono preamplifier with RCA jacks.
Reference : 8459
199,00 €tax incl.
165,83 € tax excl.
Resolutely Audiophile in its design, it is particularly useful for connecting old record players to our modern equipment, giving them an extra chance to amaze us with their inimitable analog sound.
Rarely elegant with its grey striated black nylon sheath and satin-look connectors, the Mahone attests to the love of its designers for beautiful things, whether visual or auditory.
But it also bears witness to the seriousness of their approach to technical considerations.
Thus the RCAs are plated with 24k fine gold and teflon insulated, while each bond is made with solder containing 5% Silver.
The Mahone reading arm cable has been carefully designed and manufactured from a thin copper OCC copper fiber covered with dielectric PE.
The 4 cores are of the same size and harmonize around a single conductor with the same number of conductors and size. They are properly twisted followed by a mylar and copper drain for excellent EMI / RFI rejection.
New to the 1877 range, the Mahone provides a clear, controlled but quality transfer.
Specifications:
  • Number of Drivers: 4
  • Composition of Conductors: OCC Copper
  • Input: 2 x RCA + 24k Gold Plated Ground + Teflon Insulation
  • Output: 2 RCA sockets + 24k Gold Plated Ground + Teflon Insulation
  • Shielding: Copper + PET (Polyethylene Terephthalate) Insulation Sheathing
  • Total Cable Length: 1.5m
  • Finish: Black & Grey nylon sheath
Length (m)1.5
ShieldingYes
Section (mm²)N/A
ConnectorRCA
2 reviews
Excellent pour le prix
J'ai hésité entre le Majestic (OCC et meilleur blindage du câble et plus luxueux) et celui-ci, pas déçu, il y a l'essentiel, poids et le dynamisme, mais avec beaucoup de détails intérieurs et la délicatesse. Très bonne mise au point stéréo et localisation des instruments et voix.
C'est un câble a un prix intéressant, si vous avez besoin d'un peu plus de détails et de délicatesse, en fonction des musiques écoutés.
J'utilise sur Platine Vinyle Technics SL 1500 et cellule Ortofon bronze, donc assez droit et neutre comme système, ce câble apporte une petite touche de chaleur. Je conseille pour budget moyen et platines pas mal, mais pas haut de gamme.
This review has been posted for 1877PHONO THE MAHONE RCA Phono RCA - RCA Cable + Ground wire 1.5m
à recommander !
Je manque surement d’expérience dans le domaine des câbles phonos, mais le rendu est tout à fait conforme à mes attentes et les dépassent largement. Je me suis fié aux retours d’utilisateurs lus sur des forums anglophones.
Il me fallait un câble qualitativement plus en adéquation avec ma cellule MC bas niveau pour remplacer mon câble pro-ject. C’est chose faite : une image stéréo renforcée avec énormément de micro détails sur tout le spectre sonore avec beaucoup de poids et dynamisme, tout en restant naturel.
Pour 155 Euro, on en a largement plus que pour son argent.
Le seul petit moins : les pinces pour le fil de masse ne sont pas très pratiques, du moins sur mon installation.
Le petit plus superflu mais agréable au déballage : un superbe packaging.
Merci à Audiophonics de mettre à disposition cette marque méconnue en France sur son site.
The "THE Mahone RCA" cable from the famous Canadian 1877 PHONO brand allows you to connect your phono player to your phono preamplifier...
