ATOHM ZEF Modulation Cable RCA-RCA Copper OCC (Pair) 1m
True to its high-end philosophy, Atohm has developed an uncompromising RCA interconnect cable. Thanks to its unique design and rigorous choice of materials, the Atohm ZEF cable guarantees perfect signal transmission, preserving the slightest variations without any alterations or additions.
By buying this product you get 23 loyalty points
Reference : 2244
239,00 €tax incl.
199,17 € tax excl.
Shipping date: 24-04-2025.
Atohm ZEF
Interconnect cable RCA-RCA OCC copper 1m (Pair)
Atohm ZEF Câble de modulation RCA-RCA cuivre OCC 3m (La paire)
It uses conductors consisting of a single-strand OCC copper core surrounded by a silver-plated UC-OFC copper multi-strand section. Each conductor is insulated with a FEP sheath and a PVC jacket. The whole assembly is shielded by an aluminum screen, a silver-plated UC-OFC copper braid and a PTFE insulating layer, effectively rejecting interference that could alter the integrity of the signal.
Atohm ZEF's uncompromising fight against all forms of interference, combined with the exclusive use of top-quality materials, results in a wide bandwidth, exemplary neutrality and absolute precision. As a result, this cable is ideally suited to any digital connection.
The structure of ZEF cable allows both symmetrical and asymmetrical connections. It is terminated on both sides by superb CNC-machined RCA connectors, with efficient PTFE insulation. Gold-plated contacts offer excellent conductivity and resistance to oxidation.
Product typeRCA cable
Length1m
ConnectorsRCA
Conductors number2
Conductors materialSingle-core OCC copper
Multi-strands silver plated UC-OFC copper
Conductors insulationFEP sheath
PVC sheath
Cable shieldingAluminum screen
Silver plated UC-OFC braid
Cable insulationPTFE
Outer sleevePVC
FillingCotton fiber
Connectors contacts platingGold
QuantityPair
ColorCable: White
Connectors: Silver
Length (m)1.0
ShieldingYes
Section (mm²)N/A
ConnectorRCA
2 reviews
excellent câble
J'avais déjà eu une très belle surprise avec les câbles d'enceintes ZEF Max qui avaient nettement fait évoluer mon système avec une extension de la bande passante aux deux extrémités du spectre et une meilleure lisibilité sur tout le spectre, sans aucune agressivité. je suis donc naturellement passé au ZEF modulation, et ce câble est en parfaite cohérence avec le ZEF max; mon ressenti est le même; l'écoute est globalement plus naturelle. je les ai mis entre ampli et préampli (YBA 1) et je viens d'en commander une autre paire pour placer entre le DAC et le préamp.
This review has been posted for ATOHM ZEF Modulation Cable RCA-RCA Copper OCC (Pair) 1m
Surprise totale! ( Pour un melomane classique comme moi).
Une dynamique merveilleuse qui donne corps et esprit au son.
Le gain ( par rapport a un Qed 2 fois + cher ) est nettement perceptible sur les instruments à cordes.
Le rendu de l' orchestre gagne en précision. Les cuivres sont percutants à souhait.
Placé entre un lecteur Cambridge et un préampli Rega, une réussite!
 (4)
True to its high-end philosophy, Atohm has developed an uncompromising RCA interconnect cable . Thanks to its unique design and rigorous choice...
