AUDIOPHONICS CONTRAST RCA Interconnect Cable Subwoofer LFE OFC Copper Triple Shielding 5m (Unit)
The Audiophonics Contrast LFE (Low Frequency Effect) RCA cable, designed and assembled in our workshops in France, has been conceived to provide a high-performance signal transmission solution between an amplifier with LFE output and a subwoofer. It incorporates components specifically selected for low-frequency signal transmission. It uses a cable with a large cross-section central conductor and triple shielding, two ferrites and RCA connectors ensuring a high level of conductivity. Carefully crafted, it is also robust and aesthetically pleasing.
Reference : 17867
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 18-04-2025.
Audiophonics Contrast Câble de Modulation RCA Subwoofer LFE Cuivre OFC Triple Blindage 5m (Unité)
Viablue NF-B cable
Viablue NF-B cable is perfectly suited to the design of LFE cables, since it has been specifically designed by the brand to ensure powerful, vigorous low-frequency reproduction. It uses a high-purity OFC copper center conductor with a large cross-section (5.06mm²), ensuring excellent electrical conductivity. It also benefits from triple shielding, consisting of a semi-conducting layer of low-density polyethylene (LDPE) and two shields of pure OFC copper and tinned OFC copper. This effectively rejects any interference that might alter the signal, particularly at low frequencies.
Elecaudio TE-RC90S connectors
The Elecaudio TE-RC90S RCA connectors on the Audiophonics Contrast cable have been designed for optimum conductivity. They use silver-plated tellurium copper contacts, offering a very high conductivity index (IACS), while at the same time being highly resistant to oxidation. The connector is insulated by a PTFE layer, limiting the impact of interference, and clad in a robust anodized aluminum body.
Viablue ferrite
To keep interference, the real enemy of low-frequency signals, to a minimum, Audiophonics Contrast cable features Viablue ferrite on both sides, covered and held in place by Audiophonics heat-shrink tubing.
Viablue Flag braided sheath
Finally, the cable is covered with a magnificent Viablue Flag braided sheath in black, grey and white. In addition to giving the cable a sober, classy appearance, it protects it against mechanical wear, twisting and pulling.
Product typeRCA LFE cable for subwoofer
Length5m
ConnectorsMale RCA
Cable conductor materialOFC copper
Cable conductor section5.06mm²
Cable triple shielding Low-density polyethylene (LDPE)
Pure OFC copper
Tinned OFC copper
Cable conductor capacity125pF/m
Connectors contacts materialTellurium copper
Connectors contacts platingSilver
Connectors insulation materialPTFE
Connectors shell materialAnodized aluminum
Ferritex2
Covering sheathBraided sheath
Cable diameterØ8.5mm
Ferrite diameterØ18.2mm
Connectors diameterØ12.5mm
Connectors body length34.5mm
Weight540g
ColorSheath: black, gray and white
Connectors: black
Length (m)5.0
ShieldingYes
Section (mm²)5.00
ConnectorRCA
Câble avec une bonne finition, relié à un caisson il apporte un gain certain dans la lisibilité et la dynamique des graves. La longueur ne provoque pas de décalage par rapport aux enceintes.
This review has been posted for AUDIOPHONICS CONTRAST RCA Interconnect Cable Subwoofer LFE OFC Copper Triple Shielding 5m (Unit)
The Audiophonics Contrast LFE (Low Frequency Effect) RCA cable, designed and assembled in our workshops in France, has been conceived to provide a...
