By buying this product you get 126 loyalty points
Phono Cable RCA Silver Plated Copper 1.2m
Furutech offers with the AG-12 a high-end phono cable, composed on both sides of RCA connectors and a ground wire ending in a spade. This one integrates copper conductors with silver plating for a maximum conductivity. Each conductor benefits from the cryogenic treatment α (Alpha) of the brand, for a more stable transmission. The connectors are Rhodium plated and the RCA contacts are made of OCC Copper treated α (Alpha). The whole takes advantage of an effective isolation in order to drastically limit the impact of the interferences on the signal.
Product type | Phono cable |
Connectors | RCA 1x Ground wire (spade) |
Length | 1.2m |
Conductors | Silver plated OFC Copper |
Connectors contacts | OCC Copper |
Connectors contacts plating | Rhodium |
Cable diameter | Ø9.5mm |
Color | Black |
Length (m) | 1.2 |
Shielding | NC |
Section (mm²) | N/A |
Connector | RCA |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | Silver |
