NEOTECH NEMOI-1220 Shielded UP-OCC Silver Interconnect Cable RCA-RCA Ø 10mm 0.5m (Pair)
By buying this product you get 34 loyalty points
Reference : 16518
349,00 €tax incl.
290,83 € tax excl.
Shipping date: 24-04-2025.
NEOTECH NEMOI-1220
NEOTECH NEMOI-1120 Câble de Modulation Argent UP-OCC RCA-RCA Blindé Ø 10mm 2m (La paire)
The NEMOI series from the manufacturer Neotech is the result of extensive research in the field of audio cable. The Neotech NEMOI 1220 modulation cable, combining PTFE insulation and UP-OCC Silver conductors with rectangular cross-section, has a special architecture that significantly reduces the inductance and capacitance effect.
If you are looking for a very high quality cable with a flawless design, the Neotech NEMOI 1220 is for you. The result is surprising, combining with listening to often contradictory qualities such as sitting in the bass and a readable, natural sound scene with High Definition in the medium, without auditory fatigue..
Product typeRCA Cable
ConnectorsRCA - RCA
Length0.5m
ConductorsUP-OCC Silver Cross-Section
Conductors section2 x 0.33mm²
ShieldingCuivre-Mylar foil + Braided Copper
InsulationPTFE + PE + PVC + Cotton
External sheathPE + PVC
Resistance0.054 Ohm/m
Capacity38.19 pF/m
Indutance0.86 µH/m
External diameter10mm
ColorCable : Blue
Connectors : Black
Quantitéx2 (Paire)
Length (m)0.5
ShieldingYes
Section (mm²)N/A
ConnectorRCA
Conductors material (Cable)Silver
Excellent!
Dernière liaison entre le dac et le préampli à bénéficier de ce type de câble. En modulation tout est câblé en 1220, l'usb avec le Neotech argent également.
Cher, c'est certain. Heureusement 2x 50cm me suffisent.
Très belle restitution, ça dépasse tous les câbles que j'ai eus. C'est neutre, bon du grave à l'aigu. Au passage les médiums sont cohérents notamment dans le bas-médium, et l'aigu très fin et dynamique, non projeté, là où le 3220 cuivre OCC fait moins bien.
Ce n'est que mon avis subjectif, m'appuyant sur des écoutes.
 (4)
This review has been posted for NEOTECH NEMOI-1220 Shielded UP-OCC Silver Interconnect Cable RCA-RCA Ø 10mm 0.5m (Pair)
