NEOTECH NEMOI-3220 Stereo RCA Interconnect Cable OCC Copper PTFE 1m (Pair)
Reference : 11426
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 30-04-2025.
Neotech nemoi-3220The NEMOI series from manufacturer Neotech is the result of extensive research in the field of audio cable.
The modulation cable Neotech NEMOI 3220mixing insulation PTFEand conductors made of pure OCC copper with a rectangular cross section has a particular architecture allowing a strong reduction in the inductance and capacitance effect.
If you are looking for a high-resolution cable, Neotech NEMOI 3220may correspond to this expectation.
The result is surprising mixing with the listening qualities often contradictory like seated in the grave and readable, natural sound scene with a High Definition in the medium without auditory fatigue.
- NEMOI series cables use the lockable DGA-201 RCA plugs with OFC copper PIN connectors and PTFE insulation -
Neotech occ cable
- Structure of OCC Neotech N cableEMOI 3220 -
Neotech occ cable
Features:/ Strong>
  • 2 Conductors Copper OCC rectangular section
  • 3-layer insulation: PTFE and Polyethylene in second layer, PVC outer jacket
  • Connectors: RCA plugs DGA-201 PIN OFC (Locking plugs)
  • External Wire Diameter: 10mm
  • Length: 1 meter
  • Sold by pair
Neotech occ cable
Length (m)1.0
ShieldingYes
Section (mm²)N/A
ConnectorRCA
3 reviews
Excelentes
Estes cabos após 1 mês de escuta estão a impressionar bastante, o som no meu sistema tornou-se mais dinâmico, transparente e com um palco tridimensional, consigo ouvir micro detalhes que não ouvia , as vozes muito naturais, o grave forte e detalhado. Conclusão, para os meus ouvidos são uns cabos com uma relação preço/ qualidade excelente. Parabéns NEOTECH, quando tiver oportunidade irei comprar mais um par.
This review has been posted for NEOTECH NEMOI-3220 Stereo RCA Interconnect Cable OCC Copper PTFE 1m (Pair)
Et la musique prend place !
Je l'utilise depuis une dizaine de jour, ce dernier ne doit pas être encore tout a fait roder.
J'ai testé plusieurs câble RCA et jusqu'a présent c'est le meilleur!!!!
Ce qui saute vraiment aux oreilles et j'insiste énormément sur ce fait, sont avant tout la qualité naturel des instruments et le du timbre.
Du grains, belle spatialisation et un jolie médium.
Je dirai aussi que c'est un cable doux et chaleureux, je peux écouter plusieurs morceaux différents sans aucune brillance et pourtant j'ai des tweeter à ruban.
Tout est bien distingué !!!
Si il y aurait une phrase à dire je dirai que la musique sonne vrai et juste !!!!!!
Parmi les meilleurs!
D’abord visuellement le câble inspire confiance concernant le montage et la qualité ressentie des connecteurs. J’ai préféré prendre ce modèle tout monté plutôt qu’assembler avec les mêmes composants vendus sur le site. À mon avis le supplément de prix pour la version montée n’est pas énorme et j’ai la garantie d’un câble bien réalisé.
Attention au dégagement nécessaire derrière les appareils, les connecteurs sont longs, le câble n’est pas souple et de gros diamètre.
À l’écoute c’est somptueux sur tous les plans : définition, beauté des timbres, aigu très fin et doux, grave propre et défini avec l’infra tout à fait présent. Le gain est majeur comparé à mon ancien câble RCA qui est pourtant un bon modèle. J’aime beaucoup l’équilibre général, plutôt neutre légèrement chaleureux je trouve.
Je connaissais déjà le monobrin rectangulaire Neotech UP OCC, ayant monté des câbles usb pour liaison PC vers dac. Actuellement du PC jusqu’au préampli je suis intégralement avec ce conducteur.
Qualité superlative pour un prix justifié, restant contenu.
 (3)
