NEOTECH NEMOI-5220-2 OFC RCA Stereo Modulation Cable PTFE (Pair) 2m
Reference : 11424
149,90 €tax incl.
124,92 € tax excl.
Neotech occ cableThe NEMOI series from manufacturer Neotech is the result of extensive research in the field of audio cable.
The modulation cable Neotech NEMOI 5220mixing insulation PTFEand pure rectangular section OFC copper conductors has a particular architecture allowing a strong reduction in the inductance and capacitance effect.
If you are looking for a high-resolution cable, Neotech NEMOI 5220may correspond to this expectation.
The result is surprising mixing with the listening qualities often contradictory like seated in the grave and readable, natural sound scene with a High Definition in the medium without auditory fatigue.
- NEMOI series cables use RCA plugs DGA-202 with PIN OFC connectors and PTFE insulation -
Neotech DG 202 ofc rca connector
- Structure of the OFC cableNeotech NEMOI 5220 -
Neotech occ cable
Features:/ Strong>
  • 2 Conductors OFC copper with rectangular section
  • 3-layer insulation: PTFE and Polyethylene in second layer, PVC outer jacket
  • Connectors: RCA plugs DGA-202 PIN OFC
  • External Wire Diameter: 8.5mm
  • Length: 2 meters
  • Sold by pair
Neotech occ cable
Length (m)2.0
ShieldingYes
Section (mm²)N/A
ConnectorRCA
