OYAIDE AZ-910 RCA Interconnect Cable 5N Pure Silver Triple Shielding 1m
The Oyaide AZ-910 is a high-end RCA cable based on the use of the best possible components to ensure maximum conductivity. The AZ-910 is a high-end RCA cable using the best possible components to ensure maximum conductivity and incorporates an FTVS-910 Oyaide cable with high purity 5N Silver conductors obtained through advanced manufacturing processes.
By buying this product you get 91 loyalty points
Reference : 14309
919,00 €tax incl.
765,83 € tax excl.
Shipping date: 22-04-2025.
Oyaide AZ-910
Oyaide AZ-910 Câble de Modulation RCA Argent Pur 5N Triple Blindage 1m
The Oyaide AZ-910 is a high-end RCA cable based on the use of the best possible components to ensure maximum conductivity. The AZ-910 is a high-end RCA cable using the best possible components to ensure maximum conductivity and incorporates an FTVS-910 Oyaide cable with high purity 5N Silver conductors obtained through advanced manufacturing processes. In order to minimize signal loss and the impact of interference on the signal, a highly effective PFA insulation is used. Polyethylene (PE) is used to keep the electrical permittivity to a minimum and ensure good flexibility of the cable. This assembly of components not only provides excellent conductivity, but also attenuates internal vibrations by altering the resonant point. In addition to this, a triple shielding is added. The first layer, a semiconductor, attenuates parasitic noise, the second, a copper foil protects the signal from high frequency noise and the last layer, silver-plated mesh, faces low frequency noise.
The connectors of the AZ-910 are Oyaide Genesis in a Pure Silver version. They incorporate Pure Silver contacts to match the cable conductors and maintain excellent conductivity.
Finally, the cable is covered with a magnificent transparent Polyurethane sheath with excellent mechanical properties, effectively protecting the cable from twisting and pulling.
Product typeRCA Cable
Length1m
Cable modelOyaide FTVS-910
Conductors5N Pure Silver (99.9995%) 1mm
InsulationPFA
Polyethylene foam
External sheathPolyurethane
Triple shieldingCarbon semiconductor
Copper foil
Silver Mesh
Impedance110Ω
Electrostatic capacity72.1nF/km
Attenuation74.5dB/km
Conductor resistance25Ω/km
Cable diameterØ8.5mm
ConnectorsOyaide Genesis Pure Silver version
QuantitySold in pairs
Length (m)1.0
ShieldingYes
Section (mm²)N/A
ConnectorRCA
Conductors material (Cable)Silver
The Oyaide AZ-910 is a high-end RCA cable based on the use of the best possible components to ensure maximum conductivity. The AZ-910 is a high-end...
