The OYAIDE PA-2075 RR V2 is an RCA-to-RCA phono cable featuring a high-end design that transmits a stable signal faithful to the original.
This cable features OCC "102SSC" pure copper conductors and a 3E multi-strand structure for enhanced conductivity. One of the special features of "102SSC" copper is that Oyaide removes 100% of impurities from the surface of the copper wire, polishing it with natural diamonds. 3E braiding" is a patented technology that geometrically twists strands of three different wire diameters to create a denser conductor.
The electrical capacitance of this cable is perfect for transmitting weak analog signals, thanks to its 110.0pF/m (1kHz) capacitance and 44 ohm impedance. It is therefore ideal for use with vinyl turntables.
A shielding system consisting of approximately three times the number of wires used for the conductor, plus a layer of PVC carbon, effectively protects the cable against interference. As insulation, Oyaide has chosen fluoroplastic (PFA) and a layer of polyethylene. The whole is covered by a halogen-free polyethylene outer sheath to dampen vibrations during signal transmission.
The contacts of this cable's RCA connectors and ground wire are made of rhodium-plated copper alloy for greater resistance to corrosion and oxidation. The ground wire conductor is made of silver-plated copper for high conductivity, and its diameter has been increased for more effective grounding.
Technical ccharacteristics
Product type | RCA cable |
Conductor material | Pure OCC copper |
Shielding | Carbon PVC 102SSC copper braid |
Insulation | Polyethylene and Fluoroplastic (PFA) |
Connectors | RCA to RCA |
Connectors contacts material | Copper alloy |
Connectors contacts plating | Rhodium |
Cable/connector welding | "SS47" lead-free silver solder wire |
Cable conductors cross-section | 0.5mm² (AWG20) |
Capacitance | 110.0pF/m (1kHz) |
Resistance | 44 ohms |
Cable length | 1m |
Total cable diameter | 5.2×12.4mm |
External sheath | Halogen-free anti-vibration |
GROUND WIRE SPECIFICATION | |
Ground wire conductive material | Silver-plated copper |
Ground wire cross-section | 0.3mm² (AWG22) |
Connector material | Rhodium-plated copper alloy |
Package | 1x Phono RCA cable OYAIDE PA-2075 RR V2 |
Length (m) | 1.0 |
Shielding | Yes |
Section (mm²) | 0.50 |
Connector | RCA |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
