OYAIDE TUNAMI TERZO RR RCA Interconnect Cable 1m (Pair)
This high quality modulation cable is assembled with the most famous Focus 1 connectors and a 102SSC cable, a top of the line model from Oyaide. This cable is presented to us with a new generation copper conductor, named Virgin Copper 102SSC, made of virgin, non recycled copper.
By buying this product you get 39 loyalty points
Reference : 15371
399,00 €tax incl.
332,50 € tax excl.
Oyaide Tunami Terzo RR
Oyaide Tunami Terzo RR Câble de Modulation RCA 0.7m (La paire)
This high quality modulation cable is assembled with the most famous Focus 1 connectors and a 102SSC cable, a top of the line model from Oyaide. This cable is presented to us with a new generation copper conductor, named Virgin Copper 102SSC, made of virgin, non recycled copper. Each 102SSC conductor is annealed twice and then treated by mechanical polishing to ensure perfect internal and surface purity.
The silver-plated copper strip shielding ensures long-term stability for optimal electrical and mechanical characteristics over time.
The Tunami Terzo RR V2 is an RCA cable developed for music lovers looking for lossless quality and high neutrality over the entire bandwidth for great musicality above all. The result lives up to the highly technical design: a cable with high resolution, a perfect balance between definition and timbre.
Oyaide manufactures every cable the same way: optimized engineering solutions applied to materials and manufacturing processes, complemented by meticulous craftsmanship.
Product typeRCA Cable
Length1m
ConnectorsMale RCA
ConductorsCopper
InsulationPFA + Polyethylene
Dual shieldingPE + Silver plated copper foil
External sheathPolyurethane
QuantitySold by the pair
Length (m)
  • 1.0
Shielding
  • Yes
Section (mm²)
  • N/A
Connector
  • RCA
Conductors material (Cable)
  • Copper
Conductors Plating (Cable)
  • None
Très bon câble de modulation
Ce câble est très cohérent sur l'ensemble des registres, donne de la définition et procure beaucoup de naturel à l'écoute. Les variations dynamiques sont très bien rendues mais sans exagération. Belles image et profondeur également. Il sonne très légèrement mat.
This review has been posted for OYAIDE TUNAMI TERZO RR RCA Interconnect Cable 1m (Pair)
This high quality modulation cable is assembled with the most famous Focus 1 connectors and a 102SSC cable, a top of the line model from Oyaide....
