PANGEA PREMIER SE Modulation Cable RCA-RCA 2m (Pair)
This RCA cable from Pangea is exceptionally well-built, featuring Cardas Grade One copper conductors and triple shielding with aluminum foil, silver-plated copper braiding and a carbon-filled PE jacket to protect your signal from EMI/RFI interference. Conductors are insulated with PE (polyethylene) air tubes.
By buying this product you get 23 loyalty points
Reference : 20490
235,00 €tax incl.
195,83 € tax excl.
Pangea Premier SE Interconnect cables RCA-RCA Copper Cardas Grade One Gold-plated 2m (Pair)
Pangea Premier SE : Front view
This RCA cables from Pangea are exceptionally well-built, featuring Cardas Grade One copper conductors and triple shielding with aluminum foil, silver-plated copper braiding and a carbon-filled PE jacket to protect your signal from EMI/RFI interference. Conductors are insulated with PE (polyethylene) air tubes.
Pangea Audio Premier cables feature Prime 750 RCA connectors, designed for exceptional conductivity and optimum connection. Their hollow gold-plated tellurium copper center pin ensures signal transmission with minimal loss. The use of advanced polymer insulation and a non-magnetic brass shell with a scratch- and chip-resistant black chrome coating testifies to attention to detail and commitment to quality. These low-mass connectors minimize eddy currents, reducing distortion and preserving the integrity of the audio signal. By incorporating these high-quality connectors, Premier SE cable ensures superior sonic performance for demanding audiophiles.
Product typeRCA interconnect cables
Connectors2x Males RCA
Length2m
Cable conductor materialCardas Grade One Copper
Matériau contacts connecteursTellurium copper
Plating contacts connectorsGold
Cable diameterØ14.65mm
PackagePair
Length (m)2.0
ShieldingYes
Section (mm²)N/A
ConnectorRCA
Conductors material (Cable)Cardas Copper
PANGEA PREMIER SE Interconnect Cables RCA-RCA Copper Cardas Grade One Gold Plated 2m (Pair)
This RCA cable from Pangea is exceptionally well-built, featuring Cardas Grade One copper conductors and triple shielding with aluminum foil,...
