PANGEA AUDIO PREMIER XL Phono RCA - RCA Cable + Ground Wire 1.25m
Pangea Audio's RCA-RCA Premier XL phono cable is a top-of-the-range cable with multi-AWG conductors made of pure Cardas grade one copper. This phono cable also has triple shielding with polyethylene (PE) tube insulation. Prime 750 RCA connectors are mounted at the ends of the cable. Pangea Audio's Premier XL sublimates analogue interconnections, making it perfect for use with turntables and preamplifiers. The final sound is clearer and more balanced than with conventional cables.
Reference : 17956
199,00 €tax incl.
165,83 € tax excl.
 Phono RCA - RCA Cable + Ground wire 1.25m
PANGEA AUDIO PREMIER XL Câble Phono RCA - RCA + fils de masse 1.25m
With its Premier XL RCA-RCA phono cable, Pangea Audio unveils a top-of-the-range cable with Cardas Grade One pure copper conductors. What's more, this phono cable benefits from triple shielding with polyethylene (PE) tube insulation. RCA Prime 750 connectors are fitted at the ends of the cable. Pangea Audio's Premier XL sublimates analog interconnections, perfect for use with turntables and preamplifiers.
Cardas Grade One copper conductors
Premier XL's conductors are made of Cardas Grade One copper, an extremely pure and conductive material. What's more, Premier XL benefits from triple shielding: silver-plated copper braid shielding, aluminum/mylar foil shielding and carbon-filled PE shielding. Pangea's cable is therefore highly protected against RFI and EMI noise. A tough, flexible thermoplastic rubber jacket protects the whole.
These Pangea brand connectors have the special feature of a very low mass to avoid eddy current problems. The center pin of this RCA connector's contacts is made of gold-plated tellurium copper, while the ground wire connectors are made of gold-plated beryllium copper. These connectors are extremely durable, protected against corrosion and oxidation. The body of the RCA connectors is made of non-magnetic brass.
Product typeRCA-RCA phono cable + ground wire
Cable length1.25m
Connectors typeRCA
Conductors materialCardas Grade One copper
InsulationPE Air Tube
ShieldingTriple layer
Silver-plated copper braid
Al-Mylar foil + Carbon-filled PE
Outer sheathNylon
Connectors contacts materialTellurium copper (RCA)
Beryllium copper (Ground wire)
Connectors contacts platingGold
Weight228g
ColorBlack and Grey
Length (m)1.25
ShieldingYes
Section (mm²)N/A
ConnectorRCA
Conductors material (Cable)Cardas Copper
Pangea Audio's RCA-RCA Premier XL phono cable is a top-of-the-range cable with multi-AWG conductors made of pure...
