PANGEA FIRST SE Phono Cable RCA / RCA with Ground 1.25m
The Pangea Premier SE is a high end vinyl turntable cable incorporating a ground conductor is a neat design. It integrates Cardas and OFC Copper conductors, PE insulation and double aluminium / OFC Copper shielding.
4.0 / 5
Reference : 13194
79,00 €tax incl.
65,83 € tax excl.
Shipping date: 22-04-2025.
Pangea Premier SE
Panger Premier SE Câble Phono RCA /RCA avec fils de masse 1.25m
Pangea's Premier SE is an excellent RCA cable for vinyl decks incorporating a ground conductor. The connectors of the latter are in the form of forks for an easy connection and an optimal contact on terminals. The Pangea Premier SE offers high performance thanks to a careful design but also with the integration of the ground conductor to connect between the vinyl turntable and the integrated preamplifier / amplifier. The special feature of this ground conductor is that it is directly integrated into the shield of the interconnecting cable for extremely low noise.
To ensure optimum conductivity, the brand uses extremely pure Copper Cardas and OFC conductors as well as gold-plated connectors. Each cable consists of several conductors of different sections with a PE dielectric layer and a double braided aluminium and OFC copper foil shielding for real noise attenuation and transparent reproduction.
Cable typeRCA / RCA Phono cable with ground wire
Length1.25m
Conductors materialCardas Copper and OFC
Connectors platingGold
Ground connectors formatSpades
Insulation materialPE
ShieldingDual : Aluminium foil and braided OFC Copper
SheathNylon
Length (m)1.2
ShieldingYes
Section (mm²)N/A
ConnectorRCA
Conductors material (Cable)Cardas Copper
2 reviews
cable pangea premier se
super cable d'un rapport qualité prix excellent. Seul bémol qui lui coute une étoile (à mon avis) peu de différenciation sur les fiches.
Le marquage rouge n'est pas terrible, seul ramm fait pire!!!
This review has been posted for PANGEA FIRST SE Phono Cable RCA / RCA with Ground 1.25m
En comparaison du cable fournit pour l'ATPL7, le gain n'est pas extraordinaire mais il y a eu du mieux dans la définition général du signal et la tenue du bas medium et du grave. Je recommande pour son bon rapport qualité/prix.
The Pangea Premier SE is a high end vinyl turntable cable incorporating a ground conductor is a neat design. It integrates Cardas and OFC Copper...
