PANGEA PREMIER Subwoofer LFE RCA Interconnect Cable 5m (Unit)
This Pangea Premier cable is dedicated to subwoofer and subwoofer applications with triple shielding and RCA connectors with high quality central pin profile contact.
The strong points:
  • Low noise triple shielded cable for improved bass resonance
  • RCA plug with high quality contact quality slotted profile
  • Grade One copper main conductor cardas cardas Grade One
Reference : 12398
75,00 €tax incl.
62,50 € tax excl.
PANGEA AUDIO PRemier subwoOfer
High quality subwoofer cable
Cardas Grade One Copper cable strands
This cable has an exceptional construction with 100% copper strands made of Cardas Grade one quality copper (hot central pin) considered as the best copper on earth and shielded by a triple insulation EMI / RFI silver plated and aluminium mylar. In addition, these high-purity copper strands are sheathed in PE tubes (above PTFE) using air as a natural insulator derived from Pangea brand premium cables. This subwoofer cable uses shielding per conductor, which eliminates unwanted noise for dynamic and loose bass.
RCA Prime 400 Pangea Connectors
The finishing touch of the Pangea Audio Premier Subwoofer is the beautifully crafted Prime 400 RCA plug. These premium quality RCAs feature a very advanced form of copolymer core insulation wrapped in gold-plated brass connections. The gold-plated one-piece central core is split, which gives it grip at the connection point. The premium gold plated RCA 400 with four cups snaps securely into place with the matching RCA connector. Its chrome Black Carbon Black finish adds a high-end touch and is highly resistant to scratches and aging over time.
Technical Caracteristics :
Conductor typePur Copper Cardas Grade One ( on hot point pin ) OFC ( cold point )
IsulationPE AIR TUBE
EMI / RFI shieldTriple insulation with aluminium mylar silver-plated foil
JAcket typeHigh-strength thermoplastic case
RCA conductorHigh quamity profil contact Gold plated
Soldering typeHand made assembled
Length (m)5.0
ShieldingYes
Section (mm²)N/A
ConnectorRCA
This Pangea Premier cable is dedicated to subwoofer and subwoofer applications with triple shielding and RCA connectors with high quality central...
