PANGEA Premier SE Modulation Cable RCA (pair) 1m
PANGEA Premier SE cables benefit from technologies rarely encountered in this range. An excellent alternative to the market leaders offering high quality affordable design, the first obvious choice for a quality cable.
Reference : 12395
149,90 €tax incl.
124,92 € tax excl.
This product is temporarily unavailable.
PANGEA PREMIER SE
High quality RCA stereo Cable
Cardas Grade One Copper condutors
This cable has an exceptional manufacturing offering 100% copper Grade One Cardas Grade one quality copper strands considered as the best copper on earth and shielded by a triple insulation EMI / RFI silver plated and aluminium mylar. In addition, these high-purity copper strands are sheathed in PE tubes (above PTFE) using air as a natural insulator derived from Pangea brand premium cables.
Non magnetic Tellurium hot point
A good cable is nothing without good RCA plugs and high quality contact quality. RCA Prime 750 RCA connectors in Tellurium copper ( IACS 98% central pin conductivity ) and low mass  (minimizes the effects of Foucault ) are specially developed to offer noble materials and a direct contact on RCA subbases thanks to a finely studied mechanical topology. In addition, the outer body of this RCA plug is made entirely of non-magnetic polymeric insulation, thus offering very high electromechanical qualities. All RCA Prime 750 plugs are gold-plated and Berrylium copper plated on cold point
A new technology design
The outer sheath of the Pangea Premier SE cable is made of a special thermoplastic rubber with superior mechanical resistance to stretching and reduced electrostatic effect.
Technical Caracteristics :
Conductor typePur Copper Cardas Grade One grade One
IsulationPE AIR TUBE
EMI / RFI shieldTriple insulation with aluminium mylar silver-plated foil
JAcket typeHigh-strength thermoplastic case
RCA conductorTellurium copper IACS 98% ( HOT pin central ) Berrylium ( COLD point )
Soldering typeHand made assembled
Length (m)1.0
ShieldingYes
Section (mm²)N/A
ConnectorRCA
Conductors material (Cable)Cardas Copper
PANGEA Premier SE cables benefit from technologies rarely encountered in this range. An excellent alternative to the market leaders offering high...
