PANGEA PREMIER Subwoofer LFE RCA Interconnect Cable 2m (Unit)
This Pangea Premier cable is dedicated to subwoofer and subwoofer applications with triple shielding and RCA connectors with high quality central pin profile contact.
The strong points:
  • Low noise triple shielded cable for improved bass resonance
  • RCA plug with high quality contact quality slotted profile
  • Grade One copper main conductor cardas cardas Grade One
Reference : 12397
44,90 €tax incl.
37,42 € tax excl.
Last items in stock !
Shipping date: 22-04-2025.
PANGEA AUDIO PRemier subwoOfer
High quality subwoofer cable
Cardas Grade One Copper cable strands
This cable has an exceptional construction with 100% copper strands made of Cardas Grade one quality copper (hot central pin) considered as the best copper on earth and shielded by a triple insulation EMI / RFI silver plated and aluminium mylar. In addition, these high-purity copper strands are sheathed in PE tubes (above PTFE) using air as a natural insulator derived from Pangea brand premium cables. This subwoofer cable uses shielding per conductor, which eliminates unwanted noise for dynamic and loose bass.
RCA Prime 400 Pangea Connectors
The finishing touch of the Pangea Audio Premier Subwoofer is the beautifully crafted Prime 400 RCA plug. These premium quality RCAs feature a very advanced form of copolymer core insulation wrapped in gold-plated brass connections. The gold-plated one-piece central core is split, which gives it grip at the connection point. The premium gold plated RCA 400 with four cups snaps securely into place with the matching RCA connector. Its chrome Black Carbon Black finish adds a high-end touch and is highly resistant to scratches and aging over time.
Technical Caracteristics :
Conductor typePur Copper Cardas Grade One ( on hot point pin ) OFC ( cold point )
IsulationPE AIR TUBE
EMI / RFI shieldTriple insulation with aluminium mylar silver-plated foil
JAcket typeHigh-strength thermoplastic case
RCA conductorHigh quamity profil contact Gold plated
Soldering typeHand made assembled
Length (m)2.0
ShieldingYes
Section (mm²)N/A
ConnectorRCA
Câble Subwoofer
Un câble de subwoofer exceptionnel qui pourrait se vendre pour beaucoup, beaucoup plus...
Tirez le maximum des basses fréquences de votre subwoofer avec le câble d'interconnexion pour subwoofer Pangea Audio Premier.
Conçues par le légendaire Jay Victor, les interconnexions audio Premier de Pangea Audio offrent les meilleures performances à un prix surprenant - et bien au-delà! Premier propose des innovations technologiques et les meilleurs matériaux, notamment le cuivre Cardas Grade One fabriqué aux États-Unis, considéré par beaucoup comme le meilleur cuivre disponible sur le marché. Ce cuivre coûte 20% de plus que le fameux cuivre PCOCC fabriqué au Japon, que la plupart des experts considéraient auparavant comme le meilleur cuivre au monde.
Isoler le Cardas Le cuivre est une isolation avancée en PE. Le PE est l’un des meilleurs isolateurs disponibles dans le commerce et a été choisi pour son son doux et détendu. Le câble est recouvert d’une tresse de nylon sophistiquée qui se plie facilement tout en le protégeant des fissures et des éraflures.
Conception à triple blindage
Pour rejeter le bruit et les interférences provenant du câble et de la pièce extérieure, les interconnexions Pangea Premier sont dotées d'un triple blindage. Chaque conducteur possède son propre blindage, puis le câble entier est enfermé dans des blindages séparés en feuille et en tresse.
Conception de conducteur avancée
La conception la moins chère et la plus courante généralement utilisée dans les câbles de signaux utilise un seul conducteur pour chaque canal, le retour étant le blindage uniquement. La plupart des fabricants de câbles utilisent cette conception dans leurs câbles d'entrée de gamme.
Une deuxième conception, plus avancée, utilise un conducteur de signal et un conducteur de retour séparé pour chaque canal, qui est séparé du blindage. La plupart des fabricants de câbles audio haut de gamme utilisent cette deuxième conception dans leurs câbles d'entrée de gamme.
Les interconnexions Pangea Audio Premier présentent un design beaucoup plus avancé. Les câbles Premier comportent un conducteur à noyau solide séparé Cardas Copper Grade One Copper pour les canaux droit et gauche, puis un conducteur de cuivre OFC distinct pour le conducteur de retour de chaque canal. Les conducteurs de chaque canal sont ensuite enveloppés dans un blindage en feuille afin de réduire la distorsion entre les canaux et l'ensemble du câble est blindé avec deux couches supplémentaires de blindage. Cette conception est plus coûteuse et complexe à produire, mais sonique est supérieure aux méthodes moins chères.
"Tout simplement le meilleur cuivre sur la planète"
Ce câble Pangea Audio utilise le Cardas Grade One Copper sans compromis, développé par George Cardas de Cardas Audio pour ses propres câbles premium.
Le cuivre de George est extrait en Arizona, puis expédié à une usine de Nouvelle-Angleterre où il est très lentement aspiré dans les conducteurs, processus de réduction de recuit entre les étapes permettant de purifier et de fusionner davantage le cuivre dans ce que George appelle "le plus incroyable des conducteurs audio que j'ai. C'est tout simplement le meilleur cuivre de la planète. "
"En résumé, les meilleures cartouches phono fabriquées dans le monde, les meilleurs enrouleurs de transformateur et les meilleurs fabricants de câbles au monde se convertissent à ce Cardas Grade One Copper à la sonorité lisse", rapporte George.
"Il est tout simplement stupéfiant de voir comment l’association de la technologie de l’ère spatiale (recuit par réduction) et du procédé de dessin à l’ancienne (matrices diamantées et recuit lent en plusieurs étapes) permet d’obtenir un produit aussi raffiné", déclare George.
Magnifiquement fait, Prime 400 Premium RCA
La touche finale des interconnexions Pangea Audio Premier est la superbe terminaison Prime 400 RCA. Ces RCA haut de gamme comportent une forme très avancée d’isolant à noyau en copolymère, enveloppée de connexions en laiton plaqué or. La goupille centrale pleine en une seule pièce plaquée or est fendue, ce qui lui confère une adhérence en compression au point de connexion. Le sol Prime 400 RCA est également plaqué or avec quatre coupes, de sorte qu’il adhère fermement au sol femelle RCA.
Fini chromé cuit extrêmement durable
Le RCA est recouvert d’un corps en laiton usiné au fini chrome cuit. Nous avons demandé au créateur, Jay Victor, pourquoi il avait choisi cette finition. "J'ai conçu et fabriqué plus d'une centaine de câbles RCA pour différentes marques à travers le monde et j'ai constaté qu'après des mois ou des années d'utilisation, la peinture finissait par s'écailler. Cette finition chromée est extrêmement durable et durera des années sans se fissurer s'écaillant, "répondit Jay. "Et puis, ça a l'air sexy, n'est-ce pas?" Nous sommes d'accord.
Pourquoi le bas prix? Travaillant en étroite collaboration avec le designer Jay Victor et directement avec quatre fabricants américains et asiatiques, Pangea Audio est en mesure de proposer les interconnexions audio Premier à un prix bien inférieur à celui de ses concurrents. Un essai et vous en conviendrez: c’est un câble exceptionnel qui pourrait se vendre bien plus cher encore.
This review has been posted for PANGEA PREMIER Subwoofer LFE RCA Interconnect Cable 2m (Unit)
This Pangea Premier cable is dedicated to subwoofer and subwoofer applications with triple shielding and RCA connectors with high quality central...
