High quality subwoofer cable
This cable has an exceptional construction with 100% copper strands made of Cardas Grade one quality copper (hot central pin) considered as the best copper on earth and shielded by a triple insulation EMI / RFI silver plated and aluminium mylar. In addition, these high-purity copper strands are sheathed in PE tubes (above PTFE) using air as a natural insulator derived from Pangea brand premium cables. This subwoofer cable uses shielding per conductor, which eliminates unwanted noise for dynamic and loose bass.
The finishing touch of the Pangea Audio Premier Subwoofer is the beautifully crafted Prime 400 RCA plug. These premium quality RCAs feature a very advanced form of copolymer core insulation wrapped in gold-plated brass connections. The gold-plated one-piece central core is split, which gives it grip at the connection point. The premium gold plated RCA 400 with four cups snaps securely into place with the matching RCA connector. Its chrome Black Carbon Black finish adds a high-end touch and is highly resistant to scratches and aging over time.
Spécifications | |
Conductor type | Pur Copper Cardas Grade One ( on hot point pin ) OFC ( cold point ) |
Isulation | PE AIR TUBE |
EMI / RFI shield | Triple insulation with aluminium mylar silver-plated foil |
JAcket type | High-strength thermoplastic case |
RCA conductor | High quamity profil contact Gold plated |
Soldering type | Hand made assembled |
Length (m) | 5.0 |
Shielding | Yes |
Section (mm²) | N/A |
Connector | RCA |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
