Sur une longueur de 7 métres son plus net et sans perte de qualité.
Passive RCA Modulation Extender
This RCA modulation extender is composed of two identical small boxes. Each of them has a stereo RCA input / and output and an RJ45 connector. They thus make it possible to set up a long-distance transmission without loss and without noise using Cat5e/6 Ethernet cable much more suitable for this type of use than RCA. The circuits have insulation to greatly limit EMI interference that could generate distortion and noise, such as from a ground loop or a difference in electrical potential.
Product type | RCA Extender |
Input / Output Connector | Stereo RCA |
Connector for extension cable | RJ45 |
Frequency response | 20Hz - 20kHz |
Max input signal | 1.1Vp-p |
Input / Output impedance | 600Ω |
Insulation voltage | > 800V |
Insulation resistance | 100MΩ |
Housing material | Brushed Aluminium |
Color | Champagne |
Dimensions | 148 x 110 x 60mm |
Length (m) | N/A |
Shielding | NC |
Section (mm²) | N/A |
Connector | RCA |
Connector | RJ45 |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | NC |
Average votes 4.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
