RAMM AUDIO AIR 25 Interconnect Cables RCA-RCA Copper OFHCC Gold plated 1.5m (Pair)
RAMM Audio's AIR25 is a top-of-the-range, affordable 1.5m RCA interconnect cable. The conductors of this cable are made of OFHCC copper and are triple shielded. The RCA connectors are gold-plated.
Reference : 17912
54,90 €tax incl.
45,75 € tax excl.
RAMM AUDIO AIR 25
RAMM Audio's AIR 25 is a top-of-the-range, affordable RCA interconnect cable. The conductors of this cable are made of OFHCC copper, an oxygen-free copper with high conductivity. Both conductors have a solid core to limit distortion and are separately shielded with drain wire. The AIR 25 has a triple-layer shield made of AL Mylar aluminum foil and polypropylene (a semi-crystalline thermoplastic polymer), so it is protected from noise and interference. "AIR Geometry" technology with natural cotton filling is also used by RAMM Audio in the design of this RCA modulation cable. Finally, the conductors are soldered to gold-plated Air25-782LG RCA connectors for corrosion and oxidation resistance as well as maximum conductivity.
Product typeRCA-RCA Interconnect cable
Length1.5m
ConnectorsMale RCA
Conductors materialOFHCC Copper
ShieldingTriple layer: AL Mylar and polypropylene
External sheathPVC
Connnectors contact platingGold
ColorBlack / Grey
Package2x AIR25 RAMM Audio RCA interconnect cable
Length (m)1.5
ShieldingYes
Section (mm²)N/A
ConnectorRCA
RAMM Audio's AIR25 is a top-of-the-range, affordable 1.5m RCA interconnect cable. The conductors of this cable are made of OFHCC copper and...
