RAMM AUDIO ELITE 8 PREMIUM RCA Cables OCC Copper Cryo NBU Floating Ground Gold Plated 5m (Pair)
These high-end Ramm Audio Elite8 Premium RCA cables benefit from a very high quality design designed to ensure the best audio reproduction: OCC Copper conductors, cryogenic processing and floating mass, everything is done to promote optimal signal transmission.
By buying this product you get 47 loyalty points
Reference : 16496
479,00 €tax incl.
399,17 € tax excl.
Shipping date: 25-04-2025.
Ramm Audio Elite8 Premium Câbles RCA Cuivre OCC Cryo NBU Masse Flottante Plaqué Or 1m (La paire)
These RCA Ramm Audio Elite8 Premium high-end cables offer a very high quality design, thinked to ensure the best possible audio reproduction. Their conductors are made of pure OCC Copper, allowing excellent signal conductivity. These conductors also undergo cryogenic processing in order to further improve signal transmission quality.
The assembly of the cables is particular since they take advantage of the NBU technology for Noise Bypass Unit. Thus, they integrate a floating ground, consisting in separating the shielding ground from the signal ground, making the Elite8 Premium very quiet cables thanks to a reduced noise at the maximum. The shielding ground, connected on one side only, functions as a Faraday cage, protecting the conductors from the waves and interferences.
The Elite8 Premium ends with high quality connectors with gold-plated Tellurium Copper contacts, ensuring both excellent conductivity and high oxidation resistance.
Finally, a magnificent black and gold nylon sheath covers the cable, giving it better resistance to mechanical stresses and a magnificent aesthetic.
Since these cables have a floating ground assembly, they have a connection direction that must be respected in order to take advantage of their benefits and not generate noise. The connection direction is indicated by 3 arrows on the cables.
Ramm Audio Elite 8 : Composition diagram
Ramm Audio cables comparison
Elite 8
Elite-XTRA
Elite 72 (E72)
Mozart2
Cable geometry
Air-Inside© geometry with multi-layer shielding for excellent transparency and resolution, with less distortion and noise
Conductors
Single-core OCC copper
Number of conductors
3 individually shielded conductors
2 individually shielded conductors
Conductor composition
3 wires of 0.65mm, 0.60mm and 0.55mm individually wrapped in silk thread
2 x 0.5mm PP-insulated wires
3 x 0.5mm bare wires
1 x 0.6mm bare wire
Drain wire
3 x 0.6mm OFC monocrystalline copper strands
3 x 0.5mm OFC monocrystalline copper strands
1 x 0.65mm OFC monocrystalline copper wire
Dielectric
Cotton filling
PP rods
Cotton filling
PP rods
Cotton filling
PP rods
Cotton filling
Conductors shielded by copper foil
Capacitance (pF/m)
140
203.51
203
155
Resistance (Ω/m)
0.024
0.03274
0.033
0.028
Inductance (µH/m)
1.4
1.31394
1.32
1.25
Characteristics
Natural, pure and transparent sound with smooth musicality and exceptional sound image. Quiet, excellent noise and interference rejection
Clean, natural signal transfer for dynamic performance with better-defined deep bass and smoother highs
Musical, transparent and smooth with excellent sound image
Sound image with highlighted voices. Natural sound with low distortion and noise
Connectors
Balanced connection, usually XLR
Single-ended connectors, usually RCA
Outer diameter
9.2mm
9.2mm
8.2mm
9mm
Product typeRCA Cable
ConnectorsMale RCA
Length5m
Cable conductors materialOCC Copper
Floating ground
Cryogenic treatment
Connectors contacts materialTellurium Copper
Connectors contacts platingGold
Cable diameterØ9mm
QuantitySold by pair (2 cables)
Length (m)5.0
ShieldingYes
Section (mm²)N/A
ConnectorRCA
These high-end Ramm Audio Elite8 Premium RCA cables benefit from a very high quality design designed to ensure the best audio reproduction: OCC...
