RAMM AUDIO GENESIS7 Interconnect Cable RCA-RCA 1.5m (Pair)
The Ramm Audio Genesis7 interconnect cable is an RCA interconnect cable featuring high quality construction and materials. It features 3 main conductors made up of 3 strands of 0.5mm monocrystalline graphene OCC copper for excellent signal transmission, with a conductivity level 40% higher than standard copper conductors.
By buying this product you get 32 loyalty points
Reference : 19930
329,00 €tax incl.
274,17 € tax excl.
Shipping date: 24-04-2025.
RAMM AUDIO Genesis7 Interconnect Cable RCA-RCA Graphene OCC Copper 1.5m (Pair)
RAMM AUDIO Genesis7 picture
The Ramm Audio Genesis7 interconnect cable is an RCA interconnect cable featuring high quality construction and materials. It features 3 main conductors made up of 3 strands of 0.5mm monocrystalline graphene OCC copper for excellent signal transmission, with a conductivity level 40% higher than standard copper conductors. A drain wire with three 0.5mm OCC copper conductors completes the assembly for grounding. This modulation cable also features AL Mylar aluminum multi-layer shielding, which effectively protects against EMI/RFI interference and reduces noise levels. The brand's proprietary Air Inside Geometry technology is also present, eliminating the effects of distortion. The Ramm Audio Genesis7 is sure to meet the expectations of demanding audiophiles.
RAMM AUDIO Genesis7 : 30891GT RCA connectors
Ramm Audio 30891GT RCA connectors feature gold-plated tellurium copper alloy contacts for enhanced resistance to corrosion and oxidation. Their shell is made of non-magnetic aluminum, and each contact is individually isolated for protection against interference. In addition, these connectors offer a pleasing, high-end aesthetic thanks to their black color and two stripes revealing the gold plating.
RCA 30891GT connectors picture
RAMM AUDIO Genesis7 cable structure
1Braided Nylon
2PVC sheath
3Cotton filler
4Polypropylene rods
5Graphene OCC copper
6Al Mylar
7OCC wires
Product typeRCA-RCA interconnect cable
ConnectorsRCA male 30891GT
Length1.5m
Cable conductor materialGraphene OCC copper
Cross-section3x 1mm²
ShieldingAl Mylar
InsulationPolypropylene + Cotton filler + PVC
External diameterØ9.3mm
electrical characteristics
Inductance1.4μh/m per conductors
Resistance0.03Ω/m per conductors
Capacitance184pF/m per conductors
Weight150g / cable
PackageSold by pair
Length (m)1.5
ShieldingYes
Section (mm²)1.00
ConnectorRCA
Conductors material (Cable)Graphene
RAMM AUDIO GENESIS7 Interconnect Cable RCA-RCA Graphene OCC Copper 1m (Pair)
The Ramm Audio Genesis7 interconnect cable is an RCA interconnect cable featuring high quality construction and materials. It features 3 main...
